final cut pro pro-res
Donna Valenti
on Jan 26, 2010 at 1:42:53 pm
what are the advantages/disadvantages of digitizing in the "pro-res" mode in final cut... is it a compression issue, a space issue, both???
Donna V.
Shane Ross
Re: final cut pro pro-res
on Jan 26, 2010 at 2:52:19 pm
Saves space over Uncompressed codecs. Looks as good, but less space.
Shane
John Pale
on Jan 26, 2010 at 4:26:56 pm
Uncompressed HD requires extremely fast drive arrays. Though you still need a decent RAID to do serious work using Pro Res in HD, the necessary investment is much lower
