fcp low frame rate
gyula pados
fcp low frame rate
on Jan 24, 2010 at 11:46:38 pm
I've just switched from FCP 6 to Fcp 7 .When i try to use full screen playback i am getting a really low frame rate on my imac(3Ghz ) and on my cinema display as well.I did not have this problem before.I've installed Fcp 7 to my Macbook pro no such a problem there.Any ideas ?
Thank you
Gyula
gyula
Jerry Hofmann
Re: fcp low frame rate
on Jan 25, 2010 at 1:22:41 pm
If you didn't do the upgrade as a clean install (erasing your startup disk and starting over with a fresh install of the OS, then install FCS (2009) over that, it's likely what you need to do to fix your problem.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
