Making Multiple Timelines out of Multiple Clips
Adrian Salinas
on Jan 24, 2010 at 9:59:11 am
I want to make multiple timelines out of multiple clips each on its own timeline,
I would like to know If there is a way to do this without having to do it manually one at a time.
I would greatly appreciate any help.
Adrian
Jerry Hofmann
Re: Making Multiple Timelines out of Multiple Clips
on Jan 24, 2010 at 3:17:06 pm
You can duplicate sequences in the Browser by typing cmd+d if that's what you're asking.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Adrian Salinas
on Jan 24, 2010 at 8:42:35 pm
Hi jerry thanks fro taking the time to respond my question, but sadly its not that simple, what I want to do is find a way were i can take a bin full of clips and some how make a timeline for every clip without having to do it one by one.
thanks anyway
Jerry Hofmann
on Jan 25, 2010 at 12:39:39 am
I didn't quite understand what you wanted to do. Why are you needing to do this?
Jerry
Adrian Salinas
on Jan 25, 2010 at 12:56:08 am
I am making stock clips out of lots of different footage shoot over time, I need to trim and color correct all of it and some times edit stuff out, cut the sound, etc.
I want to do this by having 1 time line per clip so at the end i can batch export.
the way im doing it now is making each timeline one by one, this is very time consuming
i would like to know it i can batch or automate this action so all the clips inside a folder go each to its own separate timeline,
thanks for the help i appreciate it
Jerry Hofmann
on Jan 25, 2010 at 5:16:59 am
You have sort of a unique problem all right... have to have clips in a sequence to send them to Color alright...
Only thing I can think of to improve a one at a time method is to put many in a single sequence, then pull the edited and corrected clips from that sequence to a browser after it's sent back from Color maybe?
Jerry
Adrian Salinas
on Jan 26, 2010 at 1:28:55 am
Hey Jerry I found something that might work, It looks really promesing for all this batching tasks
http://www.xmedit.com/ its called traffic, check it out
thanks for the help
A
Jerry Hofmann
on Jan 26, 2010 at 1:30:47 am
Ya know? I'd forgotten about this software! It may well be the ticket you're looking for indeed! It does as advertised, at least used to...
Jerry
