RT Tab Sequence window missing options FCP 7
Linda O Keeffe
on Jan 23, 2010 at 8:03:57 am
WORKING IN FCP 7 AND 6
I imported a video file from the BBC website which was in h.264 when I dragged it to the timeline, FC asked if I wanted to change the sequence settings I said yes. Now my RT Tab on the sequence window has only three options on it, Play Base Layer, Play in Safe Mode and another which is not highlighted. I restarted FCP and changed my set up in easy setup, obviously deleted the video before I did that. But the RT tab remains the same. Do I have to trash my preferences to change this.
Shane Ross
Re: RT Tab Sequence window missing options FCP 7
on Jan 23, 2010 at 8:41:06 am
H.264 isn't an RT codec in FCP. Only codecs you find in the EASY SETUP list are. If you want RT options, and good performance while editing, you need to convert the footage to a more editable codec.
Shane
