Progressive Encoding with FCP/ Compressor/ Cleaner ?!
Stefan Koler
on Jan 22, 2010 at 11:01:49 pm
I need to transform anamorphic Quicktime DV-PAL clips into progressive Quicktime H.264 (anamorphic) and MPEG-2 (anamorphic) clips.
So I exported a Quicktime DV-PAL in Final Cut Pro 6.06, imported the file to Compressor and started encoding. I used the "Deinterlace" Filter.
Unfortunately the field order is wrong after encoding, it looks bad and not like clean, progressive clips should look like.
After this I tried Autodesk Cleaner. But the result was similar: It was progressive (no fiel errors), but the quality was bad as well - lot's of artifacts....
But there needs to be a way to get clean, beautiful looking progressive footage. Can anybody tell me how to do it with Compressor or Autodesk Cleaner or if there is a better encoding software out there (I'm willing to pay for it if it works) please tell me. Or which settings/ filters should I use?
Jeremy Garchow
Re: Progressive Encoding with FCP/ Compressor/ Cleaner ?!
on Jan 22, 2010 at 11:11:31 pm
DOn't use the deinterlace filter in Compressor, but rather set your output fields to progressive in the Frame Controls tab.
The results are far superior.
