How do I add an effect to a whole sequence?
Steve Clinch
on Jan 22, 2010 at 5:50:27 pm
This is just driving me mad- I need to add the same effect to a whole sequence eg a crop / resize. How do I do this? I normally edit with Avid and you just put the effect on a new video layer and you're done. Can you do the same with FCP? Help please!!!
Kevin Monahan
Re: How do I add an effect to a whole sequence?
on Jan 22, 2010 at 6:05:47 pm
Select All, then go to Sequence > Nest Items. Then, select the nest in the timeline and press Return. Now you add a motion or filter effect for the entire sequence. You can also copy one clip and then paste attributes to the rest.
BTW, FCP doesn't have tracks like Avid, so you can't do the same trick as you thought you could do.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author - Motion Graphics and Effects in Final Cut Pro
Dan Monro
on Jan 22, 2010 at 7:43:54 pm
"You can also copy one clip and then paste attributes to the rest. "
That's the method I use. Right click copy the clip that has the attributes that you want, then select all of the other clips, right click and select "copy attributes". This opens a dialog that lets you choose which attributes you want to paste. Very cool. And, you can save them as a favorite. Also very cool...
Dan Monro
FCP, Avid, AfterFX, Atlanta
MacBook Pro 2.4 GHz Intel Core 2 Duo 2 GB ram
Mac OS X 10.5.7
GeForce 8600M GT Final Cut Pro 6.0.5 Quicktime 7.6
- OR -
2 x 3.2 Quad Xeon; 16 GB ram
Mac OS X 10.5.8
NVIDIA Quadro FX 5600 Final Cut Pro 7 Quicktime 7.6.4
