25fps to 30fps
hamp lund
25fps to 30fps
on Jan 21, 2010 at 1:11:00 pm
I have 3 cam concert footage where 2 of the cameras(canon mk2) were set to 30fps while one was set to 25fps. I used mpeg streamclip to code the one that was 25 to 30. The results are not that good, especially since the camera is a little shaky. When I have tried to use smoothcam it only makes things worse(I have made a separate thread for this). I there a better way to do this?
Rafael Amador
Re: 25fps to 30fps
on Jan 22, 2010 at 12:40:36 pm
Hi Hamp,
Try Compressor with "Frame Control: ON". Try "Retiming: Better".
Export to Prores.
rafael
http://www.nagavideo.com
hamp lund
Re: 25fps to 30fps
on Jan 22, 2010 at 1:19:04 pm
Thanks! I will try this!
