[Matt Campbell] "When editing mixed 23.98 footage into a 29.97 timeline, what is the process?"
Don't. Convert the frame rates to match. So whatever you have most of, or whatever you are delivering, convert the rest to match that.
[Matt Campbell] "Will FCP add in the proper pull-down to those 23.98 clips and leave the 29.97 material alone?"
FCP does NOT add the proper pulldown to 23.98 clips in a 29.97 timeline. It does 2:2:2:4 instead of 2:3:3:2. Just plain awful.
[Matt Campbell] "Or should you simply edit using the mixed timeline and once you have picture lock, properly convert the 23.98 clips to 29.97 with 2:3:3:2 pulldown using AE or Compressor? "
Convert BEFORE you edit. Trying to fix it after will be a nightmare. Trust me.
[Matt Campbell] "Can or should you edit using FCP speed changes for picture lock, then export those clips to Compressor or Motion for the optical flow retiming and replace in a new timeline? "
Do what looks good. If you like FCP's speed changes, use those. If you want better, go out. Do this WHILE you are editing, dont wait for picture lock.
Shane
Read my blog,
Little Frog in High Def
