HDV Capture Presets
Shawn Soucy
HDV Capture Presets
on Jan 19, 2010 at 4:09:43 am
Hey All.
New here. I've been doing SD video for 8 yrs now and I now have a couple of HDV projects to edit.
3 Cam shoot, musical performance.
1080i 60i setting.
Sony HDV playback deck.
I am capturing using HDV in the Easy Setup.
All captures are fine but the Quicktime movies are 853 X 420. Stretched Horizontally.
I want to keep this as HDV all the way thu the process and can't figure it out...
Any help out there would be greatly and humbly appreciated...
Thanks for your time
Shawn
Shawn Soucy
Spirit Media
Jerry Hofmann
Re: HDV Capture Presets
on Jan 19, 2010 at 2:28:59 pm
Post the exact properties of the captured clips as reported by Final Cut Pro.
If you use the easy setup for HDV 1080i they should come in OK, but they are not? Do they look stretched in FCP?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Shawn Soucy
on Jan 19, 2010 at 3:38:11 pm
Thanks Jerry.
Here goes...
00:10:20:05, 720X480,29.97fps, DV/DVCPro-NTSC, 306MB/sec, 48.0KHz, NTSC=CCIR,
In the inspector window for QT while playing it says the size is 853X480
Format: DV, 720 x 480 (853 x 480), Millions
16-bit Integer (Big Endian), Stereo (L R), 48.000 kHz
It surely is stretched in QT while playing...
I'm baffled...
Thanks for the help.
Shawn
Shawn Soucy
Spirit Media
