Editing DV and P2 footage together
Kurt Olerud
on Jan 12, 2010 at 10:16:53 pm
I am editing together a music video with DV footage and P2 footage and the cannot understand why the DV appears squeezed in comparison to the P2 footage. The black bars outside the frame are quite larger on the DV footage than the P2. I've tried recapturing the DV footage with various capture settings but this doesn't help. Any thoughts?
Steve Eisen
Re: Editing DV and P2 footage together
on Jan 12, 2010 at 10:55:40 pm
Your P2 footage was shot how? DVCPro HD? DV? Frame rate. How was your DV footage shot? A little more info is needed. Please be specific.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Kurt Olerud
on Jan 12, 2010 at 11:10:49 pm
The P2 footage was shot 720P/24pn and the DV footage was shot at 480i/24.
Thanks for you response...
John Fishback
on Jan 12, 2010 at 11:27:06 pm
How was the footage captured/transferred?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Kurt Olerud
on Jan 12, 2010 at 11:29:43 pm
The P2 footage was captured via fire wire using the P2CMS and then Log and Transferred into FCP. The DV footage was captured via firewire from camera into FCP using Capture Now.
Gary Askham
on Jan 13, 2010 at 10:28:35 am
I think you just answered your own question. You have some footage that is 960x720 and some footage that is 720x486. They are different sizes. You need to choose one size and then resize the other footage. Remember that the pixel aspect ratios are different too.
(To simplify things I would just use Compressor to convert your footage so it is all the same size and codec)
FCP and Avid Technical Support
Air Post Production
Shoreditch - London
