"out of Memory" errors when I try to render in FCS3
Justin McAleece
on Jan 12, 2010 at 9:14:23 am
I keep getting "out of Memory" errors when I try to render in FCS3 on Snow Leopard. ProRes HQ timeline 1080P. I can limit the layers or effects and it goes away but it seems to be getting more and more restrictive. Any ideas?
Justin McAleece
Production Manager
Video Production Services
Michael Gissing
Re: "out of Memory" errors when I try to render in FCS3
on Jan 12, 2010 at 9:38:15 am
Do you have any large stills in the timeline? A common problem when trying to render images with pixel aspects exceeding 4K is getting that error message.
Check the timeline and if necessary replace any files with excess pixels with reduced versions. Otherwise it may be a corrupt file. Try rendering small sections of the timeline and see if the error appears on particular clip.
Justin McAleece
on Jan 12, 2010 at 10:12:00 am
restarting final cut helped. it seems like it was filling up some cache but I don't really know what.
Justin McAleece
Production Manager
Ben Holmes
on Jan 12, 2010 at 12:27:33 pm
Do a search for 'out of memory' on here for previous answers I and others have given. It's nothing to do with disk space or RAM - usually it denotes a bad project file, or render.
If it persists, the best cure is to work from a previous autosave.
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
http://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
