Strange DV problem???
David Battistella
on Jan 12, 2010 at 4:22:07 am
Hi there,
So I have the Panasonic AG DV2500 deck and I am able capture footage just fine. For some reason I am getting an error from FCS 3 (unable to locate FW device) when I launch FCP (7.0).
So I can capture fine from the deck, but I can't output to the deck with print to video via FW.
Anyone seen this?
David
Peace
Rafael Amador
Re: Strange DV problem???
on Jan 12, 2010 at 4:42:44 am
Hi david,
Really strange and no point to recall you to check your setting.
Try to open the capture capture window to establish communication with the desk.
If you get the "Device control OK", the Print to Tape should work.
Rafael
http://www.nagavideo.com
David Battistella
on Jan 13, 2010 at 12:55:26 am
Yes,
I did that but then it does not record on the deck.
David
Peace
