HDV print to video
Julie Chabot
HDV print to video
on Jan 11, 2010 at 5:40:47 pm
I am trying to output a sequence at a 59.94 frame rate on a Sony hvr 1500. I get the following message from FCP "this sequence is not compatible with HDV print to video".
I made an output yesterday at a 29.97 frame rate and had no problem. Now I need to output at 59.94 and FCP won't let me do it.
I did trash my pref. I also created in "Device Control Presets" a setting that match my sequence... I am at a loss... Do I need to use my Kona card to solve this problem or is there another way?
Jules
Shane Ross
Re: HDV print to video
on Jan 11, 2010 at 6:16:23 pm
Sony HDV doesn't do 59.94. That is a 720p format and not something it is compatible with. 29.97 only.
Shane
Julie Chabot
on Jan 11, 2010 at 8:17:45 pm
Thank you for your answer and time.
Jules
David Roth Weiss
on Jan 11, 2010 at 6:23:24 pm
In addition to to what Shane said, let me ask, why are you mastering to HDV?
When you master to HDV you lose a generation and it hits graphics and text with another bad and unnecessary compression hit. Better choices are archiving as a digital file or mastering to a format such as DVCPro or HDCam.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
A forum host of Creative COW's Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Julie Chabot
on Jan 11, 2010 at 8:12:00 pm
Thank you for the info. Although I am sorry to said I don't understand your answer completely.
We will be shooting in HDV (client's request) and I am now making screeners from archival witch I converted to 1080i at 59.94 to match my future sequence (HDV 1080i at 59.94 frame rate) So why am I loosing a generation? I am doing so not to lose quality... trying to preserve original video rate codec etc. I apologize in advance if my lack of technical knowledge is sooooo broad.
Jules
Shane Ross
on Jan 11, 2010 at 9:00:55 pm
There is no such thing as 1080i 59.94 HDV. HDV does not run at 60fps at 1080.
1080i60 is 29.97. Confusing, I know. But the "i" indicates INTERLACED, so 1080i60 60 interlaced fields, 2 fields per frame...30fps running at 29.97. 720p60 indicates PROGRESSIVE ("p")...so it is 60 full progressive frames running at 59.94.
Shane
Julie Chabot
on Jan 11, 2010 at 9:32:58 pm
Got it.
Thank you so much.
Jules
David Roth Weiss
on Jan 11, 2010 at 9:55:22 pm
[Julie Chabot] "So why am I loosing a generation?"
You are losing a generation if you print HDV back to tape on the little DV tapes, because that is the nature of HDV. It does a process called "conform," which recompresses all frames.
David Roth Weiss
Los Angeles
