digitize bug in FCP 7?
Michael Williams
on Jan 6, 2010 at 9:09:41 pm
Just starting to work in FCP 7 and have come across something that seems to be a bug after quite a bit of troubleshooting. curious if anyone else is experiencing the same issue.
When logging and capturing from tape, everything works fine unless I close the log & capture window and then batch capture clips from the browser. When it begins the capture, it stops and says "general error." It will not work again unless I do a restart. If I keep the log & capture window open and continue to digitize, it does not occur.
So far, this is not a big problem and I have been able to work, but would like to know if there is something that could eliminate the problem.
thanks,
mvw
Michael V. Williams
producer/editor
http://www.vernonvision.com
Shane Ross
Re: digitize bug in FCP 7?
on Jan 6, 2010 at 9:11:26 pm
This doesn't happen to me. If it was a bug it would happen to everyone. Try trashing preferences. Use the PREFERENCE MANAGER to do it right. http://www.digitalrebellion.com. FREE!
Shane
Michael Williams
on Jan 6, 2010 at 9:52:59 pm
Thanks, Shane. good program.
mike
Michael V. Williams
producer/editor
