FCP7 to DVCProHD layoff
Patrick Conroy
on Jan 5, 2010 at 10:39:44 pm
Hi all,
I have recently upgraded to FCP7 and am in the process of getting everything back to normal. I am attempting to crash record a sequence to DVCPro HD using print to video. In the past, I would hit print to video, start the record on the DVCPro deck, and then hit "OK" to begin the record. Upon upgrading both FCP7 and my Kona drivers, I am welcomed with this message..."Incompatible compression settings. You may have attemped to output a clip with compression settings that do not match the current output settings. Try nesting the clip in a sequence with the correct settings."
Does anyone know what this message could mean? My DVCPro deck cannot generate timecode to tape, so Edit to Tape would be out. I am working in a DVCPro timeline, and everything is exactly the same as it has been in the past 3 years, so this is very interesting to me.
Any help would be greatly appreciated. Thank you in advance.
-Pat
Pat Conroy
Shane Ross
Re: FCP7 to DVCProHD layoff
on Jan 5, 2010 at 11:34:22 pm
Do you have any stills in the timeline? Are they CMYK and not RGB perchance?
What deck?
Shane
Patrick Conroy
on Jan 6, 2010 at 2:51:25 pm
No stills at all. The timeline includes DVCPRO HD Footage, and Motion templates for our graphics.
The deck is a Panasonic HD1200A. The interesting thing is,I can play the timeline and layoff the tape that way, although that is not the ideal method, i.e. someone hits a button accidentally and ruins the layoff.
Anything you think I should try would be great. I am going to be messing with some settings in the meantime to get it working.
Thanks Shane
-Pat
Pat Conroy
