Mouse question: Shortcut to scroll left/right in timeline
Edward Calabig
on Jan 2, 2010 at 7:11:01 pm
I recently switched away from the mighty mouse to a mouse with only a vertical wheel scroll so I'm having trouble scrolling horizontally in the timeline. Is there a keyboard shortcut to make it so I can move the mouse left/right to look through the timeline? Are there any other shortcuts I should know that can make the transition easier?
Thanks.
Steve Eisen
Re: Mouse question: Shortcut to scroll left/right in timeline
on Jan 2, 2010 at 7:55:28 pm
You can take you hand off the mouse and use JKL.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Steve Eisen
on Jan 2, 2010 at 7:57:34 pm
iKeysToGo if you have an iPhone! If not, you can check out the keyboard shortcuts in FCP.
Steve Eisen
Vice President
Shane Ross
on Jan 2, 2010 at 9:07:01 pm
Press the Shift key while using the scroll wheel. No scroll wheel? Outta luck.
Shane
Elijah Lynn
on Jan 31, 2010 at 9:38:20 pm
Just had the exact same issue as Edward! Batteries on the might mouse are dead and had to go corded. Very helpful Shane!
Jerry Alto
on Jan 3, 2010 at 12:04:09 am
Edward- A couple that work for me.... the up and down arrows to jump through edit points in the timeline. Customize your own keystroke for zooming in and out on the CTI.
HTH,
Jerry
G5 Dual 3GB Ram
FCP Studio 6.02
External 1 TB SATA Raid 0
Kona LH, Second system w AJA ioLA
Sony Z-1
GV-HD700
