FCP no video in log & capture, then crashing
May Bolton
on Jan 2, 2010 at 6:37:19 pm
Hello folks,
I am having a problem with two FCP related things. I am using FCP v 5.1 and trying to capture HDV 1080i25p footage through a firewire from my Sony Z7. The first issue is that there does not appear to be any preset for this format only 720p and interlaced presets for HDV. As it happens, after reading around on the net I have selected 1080i50 and have changed the field order to 'none' and all the other settings are HDV etc.
The real issue is that when I ope Log and Capture, I can control the deck/camera fine and the screen shows the timecode as I play the tape but there no video showing in the L&C window. When I try and capture it says no video from the device.
I have tried trashing prefs and refreshing A/V Devices. I have no idea how to fix this issue so I can go ahead and capture this material.
The second issue is that FCP keeps crashing as I try and find solutions to problem 1 above. Below is the crash log but I am clueless as to what it means. I would be so grateful for an explanation and hopefully a solution. Thanks a lot!
Process: Final Cut Pro [468]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 5.1 (5.1)
Build Info: FCPApp-602161028~4
Code Type: X86 (Native)
Parent Process: launchd [73]
Date/Time: 2010-01-02 20:27:40.789 +0200
OS Version: Mac OS X 10.6.2 (10C540)
Report Version: 6
Interval Since Last Report: 355254 sec
Crashes Since Last Report: 8
Per-App Interval Since Last Report: 8599 sec
Per-App Crashes Since Last Report: 8
Anonymous UUID: 45863174-2B96-40C4-9288-7AB365B768BF
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000005
Crashed Thread: 9
Application Specific Information:
objc_msgSend() selector name: timecodeChanged:
Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x93a048da mach_msg_trap + 10
1 libSystem.B.dylib 0x93a05047 mach_msg + 68
2 com.apple.CoreGraphics 0x925cfbdb _CGSReenableUpdateForConnections + 222
3 com.apple.CoreGraphics 0x925cfa1e CGSReenableUpdateForConnections + 388
4 com.apple.CoreGraphics 0x925cf895 CGSReenableUpdate + 32
5 com.apple.HIToolbox 0x906a1421 EnableScreenUpdates + 46
6 com.apple.HIToolbox 0x906f84b0 AdjustToNewWindowActivation(WindowData*, WindowContext*, OpaqueWindowPtr*, unsigned char, WindowData*) + 260
7 com.apple.HIToolbox 0x909399eb HideWindow + 258
8 com.apple.AppKit 0x940e711e -[NSWindow _reallyDoOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 2604
9 com.apple.prokit 0x0099d1a5 -[NSProWindow(_ProSplash) _reallyDoOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 181
10 com.apple.AppKit 0x940e6691 -[NSWindow orderWindow:relativeTo:] + 105
11 com.apple.prokit 0x009bb817 -[NSProWindow orderWindow:relativeTo:] + 74
12 com.apple.AppKit 0x9416f551 -[NSWindow orderOut:] + 50
13 com.apple.AppKit 0x942ff105 -[NSWindow _close] + 430
14 com.apple.AppKit 0x94320d02 -[NSWindow __close] + 241
15 com.apple.AppKit 0x94320c01 -[NSWindow _close:] + 171
16 com.apple.AppKit 0x9412df86 -[NSApplication sendAction:to:from:] + 112
17 com.apple.AppKit 0x9420d705 -[NSControl sendAction:to:] + 108
18 com.apple.AppKit 0x942091ba -[NSCell _sendActionFrom:] + 169
19 com.apple.AppKit 0x942084b1 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 1808
20 com.apple.AppKit 0x9425d95d -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 524
21 com.apple.prokit 0x009d12e3 -[NSProButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 293
22 com.apple.AppKit 0x94206f07 -[NSControl mouseDown:] + 812
23 com.apple.AppKit 0x94204f10 -[NSWindow sendEvent:] + 5549
24 com.apple.prokit 0x009bb736 -[NSProWindow sendEvent:] + 264
25 com.apple.FinalCutPro 0x0043fc28 -[KGProWindow sendEvent:] + 148
26 com.apple.AppKit 0x947763da carbonAppWindowMouseHandler + 261
27 com.apple.AppKit 0x947777b0 carbonAppWindowHandler + 131
28 com.apple.HIToolbox 0x9066ee29 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
29 com.apple.HIToolbox 0x9066e0f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
30 com.apple.HIToolbox 0x90690981 SendEventToEventTarget + 52
31 com.apple.HIToolbox 0x906a24f7 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1417
32 com.apple.HIToolbox 0x9066f27a DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
33 com.apple.HIToolbox 0x9066e0f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
34 com.apple.HIToolbox 0x90690981 SendEventToEventTarget + 52
35 com.apple.HIToolbox 0x9081981b ToolboxEventDispatcher + 86
36 com.apple.HIToolbox 0x90819953 RunApplicationEventLoop + 243
37 com.apple.FinalCutPro 0x00137f94 KGMainEvent(void*) + 46
38 com.apple.FinalCutPro 0x00285ac9 main + 59
39 com.apple.FinalCutPro 0x00003692 _start + 228
40 com.apple.FinalCutPro 0x000035ad start + 41
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x93a2b0ea kevent + 10
1 libSystem.B.dylib 0x93a2b804 _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x93a2acc3 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x93a2aa68 _dispatch_worker_thread2 + 234
4 libSystem.B.dylib 0x93a2a4f1 _pthread_wqthread + 390
5 libSystem.B.dylib 0x93a2a336 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x93a23856 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x96e34ddd __CFSocketManager + 1085
2 libSystem.B.dylib 0x93a31fbd _pthread_start + 345
3 libSystem.B.dylib 0x93a31e42 thread_start + 34
Thread 3:
0 libSystem.B.dylib 0x93a04922 semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x93a3245c _pthread_cond_wait + 1089
2 libSystem.B.dylib 0x93a7b503 pthread_cond_wait + 48
3 com.apple.FinalCutPro 0x003cfedf Synchronizable::Wait() + 47
4 com.apple.FinalCutPro 0x003c036a DisplayQueue::Run() + 702
5 com.apple.FinalCutPro 0x003f6650 Thread::RunHelper(void*) + 20
6 libSystem.B.dylib 0x93a31fbd _pthread_start + 345
7 libSystem.B.dylib 0x93a31e42 thread_start + 34
Thread 4:
4 com.apple.FinalCutPro 0x0046cbf7 WorkUnitPerformer::Run() + 55
Thread 5:
2 com.apple.CoreFoundation 0x96df577f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x96df4864 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x96dfa7a4 CFRunLoopRun + 84
5 com.apple.DVCPROHDMuxer 0x0bb66507 AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 285
Thread 6:
5 com.apple.AVCVideoServices 0x00c0f319 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 149
Thread 7:
0 libSystem.B.dylib 0x93a0493a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x93a32445 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x93a61028 pthread_cond_timedwait_relative_np + 47
3 ...ple.CoreServices.CarbonCore 0x93193235 TSWaitOnConditionTimedRelative + 242
4 ...ple.CoreServices.CarbonCore 0x93192f73 TSWaitOnSemaphoreCommon + 511
5 ...ickTimeComponents.component 0x97534035 ReadSchedulerThreadEntryPoint + 4698
Thread 8:
0 libSystem.B.dylib 0x93a32806 __semwait_signal + 10
1 libSystem.B.dylib 0x93a324c2 _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x93a34158 pthread_cond_wait$UNIX2003 + 73
3 com.apple.CoreVideo 0x9224d0c8 CVDisplayLink::runIOThread() + 988
4 com.apple.CoreVideo 0x9224ccd0 startIOThread(void*) + 156
5 libSystem.B.dylib 0x93a31fbd _pthread_start + 345
6 libSystem.B.dylib 0x93a31e42 thread_start + 34
Thread 9 Crashed:
0 libobjc.A.dylib 0x934e2edb objc_msgSend + 27
1 com.apple.CoreFoundation 0x96e139a9 __CFXNotificationPost + 905
2 com.apple.CoreFoundation 0x96e133da _CFXNotificationPostNotification + 186
3 com.apple.Foundation 0x915d6094 -[NSNotificationCenter postNotificationName:object:userInfo:] + 128
4 com.apple.Foundation 0x915e3471 -[NSNotificationCenter postNotificationName:object:] + 56
5 com.apple.proapps.MIO 0x00930f82 FireWireDevice::PollTimecode() + 532
6 com.apple.proapps.MIO 0x00945856 CanonXLH1::Run() + 138
7 com.apple.proapps.MIO 0x00943218 Thread::RunHelper(void*) + 20
8 libSystem.B.dylib 0x93a31fbd _pthread_start + 345
9 libSystem.B.dylib 0x93a31e42 thread_start + 34
Thread 10:
0 libSystem.B.dylib 0x93a2a182 __workq_kernreturn + 10
1 libSystem.B.dylib 0x93a2a718 _pthread_wqthread + 941
2 libSystem.B.dylib 0x93a2a336 start_wqthread + 30
Thread 9 crashed with X86 Thread State (32-bit):
eax: 0x0fe86800 ebx: 0x915e1128 ecx: 0x00949180 edx: 0x0feb8c48
edi: 0x00000005 esi: 0xb0540c60 ebp: 0xb0540cd8 esp: 0xb0540c24
ss: 0x0000001f efl: 0x00010206 eip: 0x934e2edb cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x00000005
Binary Images:
0x1000 - 0x5e8fc7 com.apple.FinalCutPro 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0x921000 - 0x926ff3 com.apple.proapps.ProTimecode 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/ProTimecode.framework/Versions/A/ProTimecode
0x92d000 - 0x951ffb com.apple.proapps.MIO 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
0x96c000 - 0x96ffff +KGCore ??? (???) /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
0x976000 - 0x976ff7 com.apple.iokit.dvcomponentglue 1.9.9 (1.9.9) <2BA05DB9-D847-CBC7-42D6-A9D96D7E1ED2> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0x97a000 - 0xb2dfeb com.apple.prokit 5.0.1 (906) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0xc00000 - 0xc1ffff com.apple.AVCVideoServices 1.0 (28) /Applications/Final Cut Pro.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
0xc79000 - 0xcb9ff7 com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/vmutils
0xd00000 - 0xd00fff +ProMediaIOUnit ??? (???) /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIOUnit.framework/Versions/A/ProMediaIOUnit
0xdf8000 - 0xdfbff3 com.apple.FinalCutPro.Plugins.AudioGroupsExport 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
0xe00000 - 0xe83fd3 +ProMediaIOClasses ??? (???) /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIOClasses.framework/Versions/A/ProMediaIOClasses
0xefa000 - 0xefbfff com.apple.FinalCutPro.Plugins.Text Window 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
0xf00000 - 0xf42ffb +ProMediaIO ??? (???) /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIO.framework/Versions/A/ProMediaIO
0xffa000 - 0xffafff com.apple.FinalCutPro.Plugins.Vector Accelerator 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
0x165a000 - 0x1685fff com.apple.FinalCutPro.Plugins.AfterEffects 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
0x168d000 - 0x16a3ff3 com.apple.FinalCutPro.Plugins.AudioMixer 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
0x16b0000 - 0x16fcfff com.apple.audio.midi.CoreMIDI 1.7 (42) <670CB7F9-AA00-86F3-6623-E1335F7AEA83> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x1721000 - 0x1735fcf com.apple.proapps.ControlSurfaceSupport 2.0 (54) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
0x174b000 - 0x1750ff3 com.apple.FinalCutPro.Plugins.Cache Manager 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
0x1754000 - 0x1767fff com.apple.FinalCutPro.CinemaTools 3.1 (3.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
0x1770000 - 0x177afc5 com.apple.FinalCutPro.Plugins.CTHelper 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
0x1780000 - 0x17a2fff com.apple.FinalCutPro.Plugins.EditTape 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
0x17af000 - 0x17b6ffb com.apple.FinalCutPro.Plugins.Effect Builder 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
0x17ba000 - 0x17c5fff com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
0x17cd000 - 0x17deffb com.apple.FinalCutPro.Plugins.FilterCustomEd 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
0x17e2000 - 0x17f5fff com.apple.FinalCutPro.Plugins.FilterViewer 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
0x17f9000 - 0x17fcfff com.apple.FinalCutPro.Plugins.LayerFileReader 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
0x48db000 - 0x48e6ff3 com.apple.FinalCutPro.Plugins.GenViewer 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
0x48ea000 - 0x48edffb com.apple.FinalCutPro.Plugins.MolokiniSupport 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
0x48f2000 - 0x48f6fff com.apple.FinalCutPro.Plugins.NuggetExport 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
0x6bb7000 - 0x6c60fef com.apple.FinalCutPro.Plugins.Browser 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
0x6c74000 - 0x6cb8fe3 com.apple.FinalCutPro.Plugins.EDL Export 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
0x6ccc000 - 0x6cfbfe9 com.apple.FinalCutPro.Plugins.FCS Engine 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
0x6d02000 - 0x6d20fef com.apple.FinalCutPro.Plugins.Flash 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
0x6d2f000 - 0x6d7bfe7 com.apple.FinalCutPro.Plugins.Media Manager 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
0x6d86000 - 0x6d9afef com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
0x6da7000 - 0x6dbafff com.apple.FinalCutPro.Plugins.Motion Viewer 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
0x6dbe000 - 0x6dd7ffb com.apple.FinalCutPro.Plugins.Movie Analyzer 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
0x6de2000 - 0x6df0fef com.apple.FinalCutPro.Plugins.Movie Viewer 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
0x6df4000 - 0x6eaaff7 com.apple.FinalCutPro.Plugins.OMF Audio Export 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
0x6ec6000 - 0x6ed6fff com.apple.FinalCutPro.Plugins.P2Support 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/P2Support.bundle/Contents/MacOS/P2Support
0x6edf000 - 0x6ee7ff3 com.apple.FinalCutPro.Plugins.Perf Analyzer 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
0x6eeb000 - 0x6efbffd com.apple.FinalCutPro.Plugins.ProAppsIntegration 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
0x6f07000 - 0x6f12ff3 com.apple.FinalCutPro.Plugins.Pulldown Support 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
0x6f18000 - 0x6f4cfef com.apple.FinalCutPro.Plugins.QTM Reader 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
0x6f55000 - 0x6f5dfe3 com.apple.FinalCutPro.Plugins.QuickView 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
0x6f61000 - 0x6f6dfff com.apple.FinalCutPro.Plugins.Relink Media 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
0x6f71000 - 0x6fe9fed com.apple.FinalCutPro.Plugins.Timeline Editor 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
0x6ff2000 - 0x6ff8ff3 com.apple.FinalCutPro.Plugins.Transcoder 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
0x6ffd000 - 0x700effb com.apple.FinalCutPro.Plugins.Transition Viewer 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
0x7012000 - 0x7026fff com.apple.FinalCutPro.Plugins.Trimming 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
0x702a000 - 0x7031fff com.apple.FinalCutPro.Plugins.VDUSupport 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
0x7036000 - 0x7046fff com.apple.FinalCutPro.Plugins.VideoLog 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
0x704a000 - 0x7061fcb com.apple.FinalCutPro.Plugins.VoiceOver 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
0x7066000 - 0x707504f com.apple.FinalCutPro.Plugins.Waveform Monitor 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Waveform Monitor.bundle/Contents/MacOS/Waveform Monitor
0x7079000 - 0x70d2fff com.apple.FinalCutPro.Plugins.XML Support 5.1 (5.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
0x7b49000 - 0x7b58ffd com.apple.FCP Uncompressed 422.component 1.3 (1.3) /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0x7b88000 - 0x7b8afff com.apple.LiveType.component 2.1 (2.1) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x7b8f000 - 0x7d00ff7 GLEngine ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x7d31000 - 0x8137fef libclh.dylib ??? (???) <3ACD0D90-B1E9-59DA-729E-7E97092F9A24> /System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/libclh.dylib
0x815b000 - 0x8177ff7 GLRendererFloat ??? (???) <8FF7B576-512C-C2F8-4C0C-967FB3D9EEA2> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x8195000 - 0x8199ff3 com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x81a1000 - 0x857dfe3 QuickTimeH264.scalar ??? (???) /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
0x85d7000 - 0x8607fe7 com.apple.DVCPROHDCodec 1.2 (220) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
0x860d000 - 0x865afce com.apple.AppleHDVCodec 1.1 (156) /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
0x8663000 - 0x867dfc3 com.apple.AppleIntermediateCodec 1.2 (145) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x8682000 - 0x8699ff7 com.apple.IMXCodec 1.1 (128) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0x869d000 - 0x86b6fe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x89c0000 - 0x89c6ffb com.apple.audio.AppleHDAHALPlugIn 1.7.9 (1.7.9a4) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x89cb000 - 0x89d6fcb com.apple.fcp.TundraOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
0x89e0000 - 0x89e5fe7 com.apple.DesktopVideoOut 1.2.4 (1.2.4) /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
0x89ea000 - 0x89eaff7 libmx.A.dylib ??? (???) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
0x89f4000 - 0x8a2dfc9 com.apple.soundtrackpro.integration 1.0.1 (1.0.1) /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
0x8a42000 - 0x8a4cfff com.apple.DVCPROHDVideoOutput 1.2 (1.2) /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
0x8aa8000 - 0x8ab2ff7 com.apple.IOFWDVComponents 1.9.9 (1.9.9) <5B4E7BD7-EF5A-2F5C-DF8E-3D4A7B59F779> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
0x9100000 - 0x9835fdf +com.borisfx.TextScrambler ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
0xa5f7000 - 0xad29fc7 +com.borisfx.Title3D ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title 3D.bundle/Contents/MacOS/Title 3D
0xbb55000 - 0xbb9cfef com.apple.DVCPROHDMuxer 1.2 (1.2) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0xbd00000 - 0xc430fef +com.borisfx.TitleCrawl ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title Crawl.bundle/Contents/MacOS/Title Crawl
0xce6d000 - 0xd5a3ff7 +com.borisfx.VectorShape ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Vector Shape.bundle/Contents/MacOS/Vector Shape
0xe500000 - 0xe552fc3 com.apple.DVCPROHDAudio 1.2 (1.2) /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
0xe5b0000 - 0xe5c4fcf com.apple.fcp.DVOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
0xe775000 - 0xe7b6fe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0xe7bd000 - 0xe7f9fe3 com.apple.QuickTimeFireWireDV.component 7.6.3 (1591.3) <55A49215-3C98-20A3-02EC-FDBAD3D1A69B> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0xe805000 - 0xe8bafe7 libcrypto.0.9.7.dylib ??? (???) <4917E4F2-817F-5AC4-3FBE-54BC96360448> /usr/lib/libcrypto.0.9.7.dylib
0x10000000 - 0x10055fff com.apple.proapps.AudioMixEngine 2.0 (54) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
0x1085e000 - 0x10865ffb com.apple.IOFireWireAVCLib 4.0.6 (4.0.6) <5D2F23E8-F2E5-9A20-9777-2017AC2223CE> /System/Library/Extensions/IOFireWireAVC.kext/Contents/PlugIns/IOFireWireAVCLib.plugin/Contents/MacOS/IOFireWireAVCLib
0x1086c000 - 0x10891fc7 com.apple.MPEGAudioDecoder 1.0 (1.0) /Library/Application Support/ProMediaIO/Components/MPEGAudioDecoder.component/Contents/MacOS/MPEGAudioDecoder
0x10bbd000 - 0x10bdaff7 com.apple.IOFireWireLib 4.1.7 (4.1.7) /System/Library/Extensions/IOFireWireFamily.kext/Contents/PlugIns/IOFireWireLib.plugin/Contents/MacOS/IOFireWireLib
0x29a00000 - 0x29a0afff com.apple.compressor.MediaServerAPI 2.1 (2.1) /Library/Frameworks/MediaServerAPI.framework/MediaServerAPI
0x29b00000 - 0x29b90331 com.apple.AECore 2.0 (2.1) /Library/Frameworks/AECore.framework/Versions/A/AECore
0x29c00000 - 0x29c00ffc com.apple.compressor.stomp 2.1 (2.1) /Library/Frameworks/Compressor.framework/Compressor
0x29d00000 - 0x29d27ff3 com.apple.compressor.ImageProcessing 2.1 (2.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
0x29e00000 - 0x29e08fff com.apple.compressor.StompUtil 2.1 (2.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
0x29f00000 - 0x29f60ff7 com.apple.compressor.StompTypes 2.1 (2.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
0x2a000000 - 0x2a006047 com.apple.compressor.FilterUI 2.1 (2.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
0x2a100000 - 0x2a1d7fff com.apple.compressor.transcoding 2.1 (2.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
0x2a300000 - 0x2a331fff com.apple.compressor.StompUI 2.1 (2.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
0x2a400000 - 0x2a400ffc com.apple.qmaster.swamp 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
0x2a500000 - 0x2a52afff com.apple.qmaster.SwampCore 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
0x2a600000 - 0x2a60afff com.apple.qmaster.SwampUtil 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
0x2a700000 - 0x2a727fff com.apple.qmaster.SwampTypes 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
0x2a800000 - 0x2a847fff com.apple.qmaster.do 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
0x2a900000 - 0x2a908fff com.apple.qmaster.SwampService 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
0x2aa00000 - 0x2aa0bff7 com.apple.qmaster.Status 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
0x2ab00000 - 0x2ab07fff com.apple.qmaster.RequestProcessing 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
0x2ac00000 - 0x2ac0bfff com.apple.qmaster.ServiceControl 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
0x2ad00000 - 0x2ad2ffff com.apple.qmaster.ContentControl 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
0x2ae00000 - 0x2ae9bfff com.apple.qmaster.JobControl 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
0x2b000000 - 0x2b00cffd com.apple.qmaster.ClusterManager 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
0x2b100000 - 0x2b119fff com.apple.qmaster.SwampUI 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
0x2b200000 - 0x2b20afff com.apple.qmaster.SwampExecutor 2.1 (2.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
0x70000000 - 0x700cbffb com.apple.audio.units.Components 1.6.1 (1.6.1) <600769A2-479A-CA6E-A214-C8766F7CBD0F> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x7f950000 - 0x7f9b3fe7 com.apple.LiveType.framework 2.1 (2.1) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x7ffd0000 - 0x7ffd7ff3 com.apple.AEProfiling 1.2 (14) /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
0x7fff0000 - 0x80001fff com.apple.AERegistration 1.2 (58) /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
0x80040000 - 0x80041fff com.apple.Helium 2.0.3 (2.0.3) /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
0x8f611000 - 0x8fa52fe7 com.apple.GeForce8xxxGLDriver 1.6.6 (6.0.6) <205911D0-3CE3-D53C-289B-319A4E4BA153> /System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/GeForce8xxxGLDriver
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
0x90003000 - 0x90006ff7 libCGXType.A.dylib ??? (???) <483FCF1C-066B-D210-7355-ABC48CA9DB2F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x90076000 - 0x90251ff3 libType1Scaler.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x90252000 - 0x902acff7 com.apple.framework.IOKit 2.0 (???) <1BE07087-27D5-0E62-F06B-007C2BED4073> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x903a4000 - 0x903c8ff7 libJPEG.dylib ??? (???) <649E1974-A527-AC0B-B3F4-B4DC30484070> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x903d0000 - 0x9040eff7 com.apple.QuickLookFramework 2.1 (327.3) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x9040f000 - 0x9042ffe7 libresolv.9.dylib ??? (???) /usr/lib/libresolv.9.dylib
0x90430000 - 0x90465ff7 libGLImage.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x90466000 - 0x90666feb com.apple.AddressBook.framework 5.0.1 (864) <878FE5D9-6C49-000F-D5D1-DF8054BFC0F0> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x90667000 - 0x9098afef com.apple.HIToolbox 1.6.2 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9098b000 - 0x90998ff7 libbz2.1.0.dylib ??? (???) <495732E1-2AC4-44FC-E633-4CBCC503B924> /usr/lib/libbz2.1.0.dylib
0x90999000 - 0x909c9ff7 com.apple.MeshKit 1.0 (49.0) <435718C1-ED40-6BCC-F0D8-67FA05CFFF1E> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x909e3000 - 0x90b71fff com.apple.JavaScriptCore 6531 (6531.5) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x90be8000 - 0x90c07fe3 libexpat.1.dylib ??? (???) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
0x90cb8000 - 0x90cd8fe7 com.apple.opencl 12 (12) <2DB56F60-577B-6724-5708-7B082F62CC0F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x90cd9000 - 0x90cf1ff7 com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x90cf2000 - 0x90d3ffeb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x90d40000 - 0x91156ff7 libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x91157000 - 0x91285fe7 com.apple.CoreData 102.1 (250) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x91286000 - 0x91388fef com.apple.MeshKitIO 1.0 (49.0) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
0x913d7000 - 0x91437fe7 com.apple.CoreText 3.1.0 (???) <79FD1B5C-2F93-4C5D-B07B-4DD9088E67DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x91438000 - 0x9143cff7 libGFXShared.dylib ??? (???) <79F4F60E-0A6D-CE9C-282E-FA85825449E3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x91545000 - 0x91595ff7 com.apple.framework.familycontrols 2.0 (2.0) /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x91596000 - 0x915caff7 libssl.0.9.8.dylib ??? (???) /usr/lib/libssl.0.9.8.dylib
0x915cb000 - 0x9183bffb com.apple.Foundation 6.6.1 (751.14) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9183c000 - 0x91850fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x91851000 - 0x91894ff7 com.apple.NavigationServices 3.5.3 (181) <28CDD978-030E-7D4A-5334-874A8EBE6C29> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x91895000 - 0x91ccaff7 libLAPACK.dylib ??? (???) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x91ccb000 - 0x91ccbff7 com.apple.vecLib 3.5 (vecLib 3.5) <17BEEF92-DF30-CD52-FD65-0B7B43B93617> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x91d45000 - 0x91d7aff7 libcups.2.dylib ??? (???) /usr/lib/libcups.2.dylib
0x91d7b000 - 0x91fddff7 com.apple.security 6.0 (36910) <32B8FA26-CD73-4C45-C15A-EF8406D51FCC> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x91fde000 - 0x921f0fff com.apple.RawCamera.bundle 2.2.1 (477) <10937A0D-0856-1B69-AE27-43BC15B7DD21> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x9220a000 - 0x9224aff3 com.apple.securityinterface 4.0.1 (37214) /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x9224b000 - 0x92269ff7 com.apple.CoreVideo 1.6.0 (43.1) <1FB01BE0-B013-AE86-A063-481BB547D2F5> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9226a000 - 0x922aeff3 com.apple.coreui 2 (113) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x92485000 - 0x924b6ff3 libTrueTypeScaler.dylib ??? (???) <6C8916A2-8F85-98E0-AAD5-0020C39C0FC9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x924b7000 - 0x924c4ff7 com.apple.opengl 1.6.5 (1.6.5) <0AE8B897-8A80-2C14-D6FC-DC21AC423234> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x924c5000 - 0x925b9fe7 libiconv.2.dylib ??? (???) <0C578460-3929-29DD-585A-DB1E0C977425> /usr/lib/libiconv.2.dylib
0x925ba000 - 0x92d9d4b7 com.apple.CoreGraphics 1.536.12 (???) <263EB5FC-DEAD-7C5B-C486-EC86C173F952> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x92d9e000 - 0x92da5ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <6BF89127-C18C-27A9-F94A-981836A822FE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x92da6000 - 0x92db3ff7 com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x92db4000 - 0x92e04fe7 libGLU.dylib ??? (???) <659ADCA2-10EC-59BD-1B0A-4928A965F1D1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92fc7000 - 0x93149fe7 libicucore.A.dylib ??? (???) <2B0182F3-F459-B452-CC34-46FE73ADE348> /usr/lib/libicucore.A.dylib
0x9314c000 - 0x9346bfe7 com.apple.CoreServices.CarbonCore 861.2 (861.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9346c000 - 0x934dcff3 com.apple.AppleVAFramework 4.7.5 (4.7.5) <464A915D-E670-FA22-7799-454259D42B82> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x934dd000 - 0x9358afe7 libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0x93880000 - 0x93972ff7 libcrypto.0.9.8.dylib ??? (???) <792B8722-3091-5E9F-E25F-67499CFE0599> /usr/lib/libcrypto.0.9.8.dylib
0x93973000 - 0x9399bff7 libxslt.1.dylib ??? (???) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x9399c000 - 0x939d6ffb libFontRegistry.dylib ??? (???) <72342297-E8D6-B071-A752-014134129282> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x939fe000 - 0x93a03ff7 com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x93a04000 - 0x93ba8feb libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
0x93ba9000 - 0x93c13fe7 libstdc++.6.dylib ??? (???) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x93c14000 - 0x93d21ff7 com.apple.MediaToolbox 0.420.18 (420.18) <31935D52-1F8D-4AB2-CCA5-4CF615CBCE24> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x93d32000 - 0x93dabff7 com.apple.PDFKit 2.5 (2.5) <58603BDB-337F-FBE3-EB11-7C31CF261995> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x93dac000 - 0x93dacff7 com.apple.quartzframework 1.5 (1.5) /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x93dad000 - 0x940a6fef com.apple.QuickTime 7.6.3 (1591.3) <803CC5FD-2369-83B5-795D-A8963620EFAC> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x940a7000 - 0x94985ff7 com.apple.AppKit 6.6.3 (1038.25) <72A9AA47-8DCB-DB07-64F5-F837E98C62D8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94986000 - 0x94987ff7 com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x94993000 - 0x94a2ffe7 com.apple.ApplicationServices.ATS 4.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x94a30000 - 0x94a39ff7 com.apple.DiskArbitration 2.3 (2.3) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x94a3a000 - 0x94a44ff7 libGL.dylib ??? (???) <76A207FE-889A-CF1B-AF9A-795EEE5A463E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x94a45000 - 0x94a48ffb com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x94a49000 - 0x94a5efff com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x94a5f000 - 0x94a7bfe3 com.apple.openscripting 1.3.1 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x94a7c000 - 0x94a7cff7 com.apple.Accelerate.vecLib 3.5 (vecLib 3.5) <3E039E14-2A15-56CC-0074-EE59F9FBB913> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x94a7d000 - 0x94a8bfe7 libz.1.dylib ??? (???) <7B7A02AB-DA99-6180-880E-D28E4F9AA8EB> /usr/lib/libz.1.dylib
0x94a8c000 - 0x94a9eff7 com.apple.CoreMediaAuthoring 0.677 (677) <197EAB61-ACCE-E5AC-08FA-2A2D4E122E86> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x94a9f000 - 0x94aa9fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x94adc000 - 0x94aecff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x94aed000 - 0x94b47fe7 com.apple.CorePDF 1.1 (1.1) <8ED0FB5F-D498-D012-DF09-DE5378D40D52> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x94b48000 - 0x94b84fff com.apple.CoreMediaIOServices 124.0 (850) <5F9B1AA3-8BB3-4E8C-2A31-F8FD5EC3F28A> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x94c9c000 - 0x94c9fff7 libCoreVMClient.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9548e000 - 0x95498ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x95499000 - 0x95547ff3 com.apple.ink.framework 1.3.1 (105) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x95548000 - 0x9559eff7 com.apple.MeshKitRuntime 1.0 (49.0) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x955a4000 - 0x955dbff7 com.apple.CoreMedia 0.420.18 (420.18) <43747711-B334-B0C7-4971-15FA586DAFBF> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x955ff000 - 0x95603ff7 libGIF.dylib ??? (???) <83FB0DCC-355F-A930-E570-0BD95086CC59> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x95604000 - 0x95615ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <7A3862F7-3730-8F6E-A5DE-8E2CCEA979EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x95621000 - 0x956feff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x956ff000 - 0x9579cfe3 com.apple.LaunchServices 362 (362) <8BE1C1A1-BF71-CE07-F3FB-6057D47AF461> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9579d000 - 0x957e1fe7 com.apple.Metadata 10.6.2 (507.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x95823000 - 0x9589afe3 com.apple.backup.framework 1.2 (1.2) <411D14B1-0E2D-25FF-F329-CE92C70DDEC3> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x9589b000 - 0x958c2ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x958c3000 - 0x958d5ff7 com.apple.MultitouchSupport.framework 204.9 (204.9) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x958d6000 - 0x958e6ff7 libsasl2.2.dylib ??? (???) /usr/lib/libsasl2.2.dylib
0x958e7000 - 0x95aa3fef com.apple.ImageIO.framework 3.0.1 (3.0.1) <598CF4F9-7542-E1A7-26D2-584933497A2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x95aeb000 - 0x95bc5ff3 com.apple.DesktopServices 1.5.3 (1.5.3) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x95bdc000 - 0x95bdeff7 libRadiance.dylib ??? (???) <462903E2-2E77-FAE5-4ED6-829AAB1980A4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x95d68000 - 0x95d83ff7 libPng.dylib ??? (???) <3F8682CD-C05B-607D-96E7-767646C77DB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x95d84000 - 0x95de8ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x95de9000 - 0x95e41fe7 com.apple.datadetectorscore 2.0 (80.7) /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x95e64000 - 0x95e64ff7 com.apple.CoreServices 44 (44) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x95e65000 - 0x95e70ff7 libCSync.A.dylib ??? (???) <9292E6E3-70C1-1DD7-4213-1044F0FA8381> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x95edd000 - 0x95efffef com.apple.DirectoryService.Framework 3.6 (621.1) <3ED4949F-9604-C109-6586-5CE5F421182B> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x95f00000 - 0x95f00ff7 com.apple.Cocoa 6.6 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x95f01000 - 0x960e3fff com.apple.imageKit 2.0.1 (1.0) <3CD99122-4DC8-00CE-4BD7-E3E1E1C71C30> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x960e4000 - 0x9610afff com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9610b000 - 0x9610bff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9610c000 - 0x96144ff7 com.apple.LDAPFramework 2.0 (120.1) <681A0B2E-BCB2-D2BA-3D02-A4989E9C7686> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x96145000 - 0x961edffb com.apple.QD 3.33 (???) <196CDBA6-5B87-2767-DD57-082D71B0A5C7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x96202000 - 0x96270ff7 com.apple.QuickLookUIFramework 2.1 (327.3) <2F51D9CB-F827-E0AF-F201-5F4244C0D02A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x96271000 - 0x962bafe7 libTIFF.dylib ??? (???) <5864AE5B-EAEB-F8B6-18FB-3D27B7895A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9632a000 - 0x963e3fe7 libsqlite3.dylib ??? (???) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x963e4000 - 0x9660fff3 com.apple.QuartzComposer 4.1 (156.10) <24293329-50D7-D12F-51B3-57976A4E52B1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x96610000 - 0x96610ff7 com.apple.Accelerate 1.5 (Accelerate 1.5) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9661b000 - 0x96747fe3 com.apple.audio.toolbox.AudioToolbox 1.6.1 (1.6.1) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x96748000 - 0x96781fe7 com.apple.bom 10.0 (164) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x96782000 - 0x968a6ff7 com.apple.CoreAUC 5.03.2 (5.03.2) <38C77DF1-6F98-4ABF-BE8F-ADA70E9C622D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x968c6000 - 0x96d74fe7 com.apple.VideoToolbox 0.420.18 (420.18) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x96d75000 - 0x96d81ff7 libkxld.dylib ??? (???) <3D2C5BA3-6A8D-C861-B346-0E19942D9AF1> /usr/lib/system/libkxld.dylib
0x96d82000 - 0x96db8fff libtidy.A.dylib ??? (???) /usr/lib/libtidy.A.dylib
0x96db9000 - 0x96f30fef com.apple.CoreFoundation 6.6.1 (550.13) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x96f31000 - 0x97ebfff7 com.apple.QuickTimeComponents.component 7.6.3 (1591.3) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x97ec0000 - 0x97f11ff7 com.apple.HIServices 1.8.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x97f12000 - 0x97f4fff7 com.apple.SystemConfiguration 1.10.1 (1.10.1) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x97f50000 - 0x97f52ff7 com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x97f53000 - 0x97f55ff7 com.apple.QuickTimeH264.component 7.6.3 (1591.3) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x97f56000 - 0x97f5aff7 IOSurface ??? (???) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x97f5b000 - 0x97f61ff7 com.apple.DisplayServicesFW 2.2 (2.2) <72C790A9-F4D2-DA92-015B-4CAF478FC0C2> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x97f62000 - 0x97fa3ff7 libRIP.A.dylib ??? (???) <9F0ECE75-1F03-60E4-E29C-136A27C13F2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x97fa4000 - 0x97fe6fe7 libvDSP.dylib ??? (???) <8F8FFFB3-81E3-2969-5688-D5B0979182E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x97fe7000 - 0x98026ff7 com.apple.ImageCaptureCore 1.0 (1.0) /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x98027000 - 0x9802efff com.apple.print.framework.Print 6.0 (237) <7A06B15C-B835-096E-7D96-C2FE8F0D21E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9802f000 - 0x980affeb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x980de000 - 0x980ebff7 com.apple.AppleFSCompression 1.0 (1.0) /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x980ec000 - 0x9816effb SecurityFoundation ??? (???) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9816f000 - 0x984d6ff7 com.apple.QuartzCore 1.6.1 (227.8) <8B90AB08-46A4-1C5C-4E71-C6AB652477B9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x984d7000 - 0x9856ffe7 edu.mit.Kerberos 6.5.9 (6.5.9) <73EC847F-FF44-D542-2AD5-97F6C8D48F0B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x98570000 - 0x98617fe7 com.apple.CFNetwork 454.5 (454.5) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x98618000 - 0x9862cffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9862d000 - 0x98637ff7 com.apple.HelpData 2.0.4 (34) <9128FFEB-0F6C-B273-FCF4-D87A20227345> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x98638000 - 0x9866bff7 com.apple.AE 496.1 (496.1) <1AC75AE2-AF94-2458-0B94-C3BB0115BA4B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9866c000 - 0x986dbff7 libvMisc.dylib ??? (???) <59243A8C-2B98-3E71-8032-884D4853E79F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x986dc000 - 0x987ddfe7 libxml2.2.dylib ??? (???) /usr/lib/libxml2.2.dylib
0x987de000 - 0x988a8fef com.apple.CoreServices.OSServices 352 (352) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x988a9000 - 0x988d3ff7 com.apple.shortcut 1.1 (1.1) /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x98915000 - 0x98918fe7 libmathCommon.A.dylib ??? (???) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x98962000 - 0x98a15fff libFontParser.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x98abf000 - 0x98b6eff3 com.apple.ColorSync 4.6.2 (4.6.2) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x98b6f000 - 0x98b75fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x98bf5000 - 0x98bf6ff7 com.apple.audio.units.AudioUnit 1.6.1 (1.6.1) <3A08510C-07F7-1A09-D6ED-1A488203ACCC> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x98bf7000 - 0x98c71fef com.apple.audio.CoreAudio 3.2.2 (3.2.2) <1F97B48A-327B-89CC-7C01-3865179716E0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x98c72000 - 0x98d03fe7 com.apple.print.framework.PrintCore 6.1 (312.3) <6D4322AF-703C-CC19-77B4-53E6D3BB18D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x98d04000 - 0x98de2fff com.apple.QuickTimeMPEG4.component 7.6.3 (1591.3) <92D35422-4D67-4B29-B803-50BACDBA47D8> /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x98dff000 - 0x98e00ff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x98e52000 - 0x98e52ff7 liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
0x98e53000 - 0x98e53ff7 com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x98e54000 - 0x98e9aff7 libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
0x98f77000 - 0x99048fe3 ColorSyncDeprecated.dylib ??? (???) <1CEB1F35-EF10-A63D-AD9E-D7BD391D4719> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x991d5000 - 0x99314fe3 com.apple.QTKit 7.6.3 (1591.3) <18F25C19-F0B8-5907-D6D6-65EC53DF0D3B> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x99315000 - 0x9940bff7 libGLProgrammability.dylib ??? (???) <82D03736-D30C-C013-BBB1-20ED9687D47F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
Model: MacBookPro5,5, BootROM MBP55.00AC.B03, 2 processors, Intel Core 2 Duo, 2.26 GHz, 2 GB, SMC 1.47f2
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.91.19)
Bluetooth: Version 2.2.4f3, 2 service, 1 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: ST9160314ASG, 149.05 GB
Serial ATA Device: HL-DT-ST DVDRW GS23N
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0x24400000
USB Device: LaCie Rugged FW/USB, 0x059f (LaCie), 0x100c, 0x26200000
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0x26500000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0237, 0x04600000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x04500000
USB Device: BCM2045B2, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8213, 0x06110000
FireWire Device: HVR-Z7E, Sony, Up to 100 Mb/sec
Brad Kopp
Re: FCP no video in log & capture, then crashing
on Jan 2, 2010 at 7:31:46 pm
not sure about your camera model but for my Sony XDcam EX3 I had to download XDcam driver and transfer software... someone here posted the link if you do a search.
Moto Guzzi rider
dog lover w/wife, Ex & 3 kids
May Bolton
on Jan 2, 2010 at 8:17:41 pm
Hi Brad,
Thanks for the advice. Why did you have to do this, is it something to do with working with HDV in some versions of FCP or something? Or are you advising this because of something you found in the crash log?
Thanks again or your help.
May
Ken Jones
on Jan 2, 2010 at 9:25:39 pm
Can FCP 5 even work with HDV?
I'm not positive but I think you might need FCP 6 or 7 to edit HDV.
