Exporting clean graphics
Dan Kallaur
on Dec 23, 2009 at 2:59:37 pm
I am attempting to export a sequence to iDVD using QT. Sequence is 1280 x 720. Graphics look fine on timeline. When I view the dvd, the images are fine, but the graphics look terrible. Any suggestions on settings to fix this? Can it be the compressor setting, QT or iDVD?
david bogie
Re: Exporting clean graphics
on Dec 23, 2009 at 4:19:18 pm
IDVD cannot do anything with that kind of format. it is going to convert everything to standard def at MPEG2. You're wasting your time and resources working at 1080 and then scaling down to SD lots of detail is getting thrown away.
bogiesan
Jaron Halmy
on Dec 27, 2009 at 6:25:47 am
What type of QT? Be sure to export using "Quicktime Movie" not "Quicktime Compression." You may be adding an unnecessary compression step.
