Comapring two sequences
Pradip Patil
on Dec 22, 2009 at 7:55:13 pm
I was wondering if it is possible to compare two sequences in FCP?
I duplicate the sequnce before making major changes to it. So after making the changes if I have to see them by comparing with the previous sequecne, Do I have any inbuilt feature?
Matt Larson
Re: Comapring two sequences
on Dec 22, 2009 at 9:21:31 pm
Put the playhead at the same place in both the new and old sequence. Drag the OLD sequence into the Viewer window from the browser. At the top of the viewer window is a "sync" button, choose "gang". Now, when you move the playhead in the timeline, the sequence in the Viewer will update and move to that position also.
This will only work if you have the play head in EXACTLY the same place before you choose Gang sync
2 x3Ghz Quad MacPro
Mac OS X 10.5.5
QT 7.5.5
FCP 6.0.5
AJA Kona 3 (6.0.1 drivers)
G-Speed XL 12 RAID
© 2018 All Rights Reserved
