outputting dv sequence to z7u
rob mottola
on Dec 21, 2009 at 3:26:56 am
outputting a dv sequence from final cut to z7u camera via firewire...
using all frames, and 720 x 480 video playback which gives me audio/video to the camera...
after outputting a 54 minute sequence to a tape, i switched tapes and started a second sequence...the audio is now scratchy sounding, sounds like digital noise...video looks fine...
played sequence on computer, sounded fine...tested the tape i just recorded to, it sounded fine on the camera's playback...
the noise only occurs when playing to the cam via firewire using all frames and the 720 x 480 video playback and the audio follows video function...
i tried another firewire cable too...
footage lives on a g tech 1 tb external drive...connected to computer via fw 800 cable...cam connected to g tech drive via fw 800 to fw 400 cable...
rob mottola
producer | director | editor
rob@east2westmediagroup.com
Jerry Hofmann
Re: outputting dv sequence to z7u
on Dec 21, 2009 at 2:31:53 pm
Sounds like you're monitoring system is getting in the way. Does it sound OK from the recorded tape directly played to a video monitor or TV set and speakers? If so look into the way you're monitoring things.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
