Capturing Hi8 without miniDv deck
Rosie Walunas
on Dec 19, 2009 at 6:25:10 pm
Is there any way to capture Hi8 tapes without a miniDV deck or camera? If so, what is the procedure?
Steve Eisen
Re: Capturing Hi8 without miniDv deck
on Dec 19, 2009 at 7:26:27 pm
You can not capture hi8 with a mini DV deck. Different format.
You will need a SONY hi8 or digital 8 camcorder or deck.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group
Rosie Walunas
on Dec 20, 2009 at 5:38:12 pm
I understand that. But if you only have a Hi8 camera/deck, is it possible to capture the footage in Final Cut without having to wire the camera through a mini DV camera or deck?
Thank you
Rick Morton
on Dec 21, 2009 at 2:51:32 pm
There are two ways. One would be to have a capture card in your computer. The video output from the camera would go into the card and get into the computer that way.
The other way is to get an analog to DV converter. This way you could capture to the computer via firewire and get right into Final Cut or iMovie. You can find these converters on line.
