Mixing XDCAM HD and DV SD 4:3... a workflow?
Alessio Gemma
on Dec 19, 2009 at 4:14:08 pm
Hello,
I need to mix XDCAM HD 422 1920x1080 50i clips with older DV PAL 4:3. I nvedr did this job, so I'd like to get some guidelines from you.
I guess that the first step is to conform the 4:3 clips to the HD size: have I to use Compressor for this job?
DV is lower first field dominance, while XDCAM top first: have I to deinterlace the clips (doing this in Compressor)?
A workflow will be strongly appreciated!
Regards,
Alessio
