Audio levels?
Sverker Hahn
Audio levels?
on Dec 12, 2009 at 4:55:01 pm
I am editing HD material to make a DVD. Thinking about audio, which levels are recommended? The footages are seascapes where one can hear waves and occasional birds. Using Audio Mixer and iMac, it seems that a level of -30 seems to good for this kind of background audio. If aiming to level 0 I have to change the settings too much, since the recorded level is quite low, even if I have had the max recording level on the camera. Or ... ?
Sverker Hahn, Stockholm
Slower is better!
Sony EX1
Final Cut Studio 2
iMac Intel
MacBook Pro 15"
Greg Ondera
Re: Audio levels?
on Dec 12, 2009 at 6:46:27 pm
Since the beginning of digital audio, no one can use 0 level as a standard, unlike analog audio. At a maximum -12db is acceptable when doing interviews, but -20db is what most pro audio guys record at so they have the headroom in case a loud noise makes the audio peak.
Greg Ondera
http://www.Plexus.tv
http://www.SurgeonToday.org
Sverker Hahn
Re: Audio levels?
on Dec 13, 2009 at 11:13:08 am
Hi, Greg,
So I wasn´t completely wrong, then? I will start with your suggestion of -20.
Thank you.
Slower is better!
Sony EX1
Final Cut Studio 2
iMac Intel
MacBook Pro 15"
Michael Gissing
Re: Audio levels?
on Dec 13, 2009 at 9:45:17 pm
Do you mean record levels in the field or post production levels?
There are standards for post production broadcast levels which has been covered here a lot so a search of the forums will help. Even if you are making a DVD it would help to know what standard levels are so that your program has the right perceived loudness.
