cross convert out problem
Joe Procopio
on Dec 10, 2009 at 8:57:58 pm
FCP 7.x, footage DVCProHD, sequence is 720p 59.94....output is supposed to be 1080i 29.97
view set to 720p, crossconvert out of EITHER Kona or BM cards introduce a single line of green across the top of the raster....AND when going to tape (HDW1800@1080i 29,97) after we set the offset correct, which is a mind boggling +00:00:10, we are off by a field...not a frame..a field...
all other settings are normal, didn't change any field dominance on the deck or sequence....
but...if we go straight out to DVCProHD @ 720, no green line, no frameoffset issues...could the cross convert be causing this field issue?
for future, I advised the client to use a 1080i preset for the sequence, even though they are editing with DVCProHD footage...
thoughts?
Broadway Video, NYC
AVID/FCP editor/engineer
Arnie Schlissel
Re: cross convert out problem
on Dec 10, 2009 at 9:44:30 pm
What are you using for genlock?
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
Joe Procopio
on Dec 10, 2009 at 9:49:39 pm
question is what haven't we tried for genlock...in 2 separate systems...lol...1080i, 720p, 525...everything but 1080p...
Broadway Video, NYC
