HD to SD through Compressor = Magenta/Pink
Andreas Karoliussen
on Dec 9, 2009 at 10:53:23 am
I´m trying to down convert HD to SD, and Compressor gives me a Magenta output.
Shot on xdcam Ex1 1920x1080 50i
Id like to convert to SD pal 10 bit uncompressed 4:2:2
Ive tried with and without frame controls on in compressor.
And the output is Magenta....
Any ideas what would give me a pink shot? and how to make compressor act nice again?
Thank You!
Andreas
(Im on a quad core intel with the latest upgrades)
Jerry Hofmann
Re: HD to SD through Compressor = Magenta/Pink
on Dec 9, 2009 at 1:34:13 pm
Post your sequence settings.
Did you render to ProRes?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Andreas Karoliussen
on Dec 9, 2009 at 2:26:18 pm
Hi, Jerry,
Sorry I wasnt clear enough about this;
It havent been into FCP yet -
Im converting so that another mac can handle it.
workflow:
Xdcam log and transfer (the stand alone app)
files from finder into compressor and convert.
I have found a workaround now: batch export from FCP.
However it would be nice to know what causes magenta output from my compressor. Or if anyone else has seen anything similar.
Andreas
Jerry Hofmann
on Dec 12, 2009 at 4:03:38 am
Sounds to me like something incompatible with the files that you transfered through Sony's app and Apple's reading of them or something along those lines. Try skipping the sony import first?
Jerry
