720p and ftp
Matthew McNulty
720p and ftp
on Dec 7, 2009 at 6:27:18 pm
Greetings!
have a 30 second spot finished on a 720p timeline (shot in 720p) a local cable advertising company would like to send this to their head-end via ftp and has suggested a deliverable in h.264... what i am worrying about is the aspect ratio... what are some suggestions for workflow/settings using compressor or perhaps straight out of FCP as to not fubar it?!
thanks much appreciated
Raymond Tuquero
Re: 720p and ftp
on Dec 7, 2009 at 7:06:23 pm
I recommend you go through Compressor and create a 720pHD H.264 file. You can change the settings to create the Aspect Ratio you are aiming for ...
Test out a minute of your video with the Default 720p H.264 settings and see what it gives you.
-Raymond Tuquero-
Houston Based Freelancer
http://www.rtuqvidere.com
Dave LaRonde
Re: 720p and ftp
on Dec 7, 2009 at 7:30:16 pm
I'm pretty sure Compressor will let you create a preset for a 1280x720, square-pixel file.
Dave LaRonde
Sr. Promotion Producer
Matthew McNulty
Re: 720p and ftp
on Dec 7, 2009 at 7:51:01 pm
thanks o'ton!
