Log & Capture Will Not Open
Jess Martinez
on Dec 4, 2009 at 8:02:52 pm
When I go under File and select Log and Capture (or hit Command 8) FCP acts like it's about to open it, but then doesn't. If I try it again, it either does the same thing or it gives me the ERRRR sound and freezes up on me to the point where I have to hard reboot the computer in order to close out of FCP.
I read that I should attempt to trash my preferences, but when I go into Library > Preferences, there is NO preference file for Final Cut Pro. Nothing there says com.apple.Finalcutpro.plist whatever.
What is going on?
Raymond Tuquero
Re: Log & Capture Will Not Open
on Dec 4, 2009 at 8:28:17 pm
Make sure you are looking under the Home computer file>Library>Preferences and not User>Library>Preferences.
Once you locate it then trash it and try again. ... Did you try to locate it in Spotlight?
-Raymond Tuquero-
Houston Based Freelancer
http://www.rtuqvidere.com
Michael Gissing
on Dec 4, 2009 at 11:26:01 pm
A better way to trash prefs is to download Digital Rebellions Preference manager software.
http://www.digitalrebellion.com/pref_man.htm
