jump between stills
Sarah Nicholus
jump between stills
on Dec 4, 2009 at 12:49:10 am
I have two still images of a map that are exactly the same except one has a pin point on it to mark a location. I want to fade the pinpoint in so it appears on the map, but when I add the transition, the map jumps slightly as if the maps were not identical. They are however, and the jump doesn't appear without the transition. I only appears sometimes like with the transition or when the images are on different video tracks.
How can I get my maps to transition smoothly with the pinpoint appearing slowly without the weird jump between images?
Sarah Nicholus
Re: jump between stills
on Dec 4, 2009 at 1:30:47 am
sorry, I just moved this to the basics forum...
david bogie
on Dec 4, 2009 at 3:04:19 pm
Probably your render settings are not set to BEST.
Even though you moved the post, c'mon back here anyway and tell us what the basics wonks told you to do.
bogiesan
Fred Miller
on Dec 4, 2009 at 9:05:05 pm
Just render the transition.
FCP Studio 2
Dual 3Gg Quad Core
4Gg RAM
KONA 2
OS 10.5.8
