Faster Render Time
Brian Bacardi
Faster Render Time
on Dec 3, 2009 at 7:46:46 pm
I started working on a project that had numerous video tracks. I started seeing my render times increasing by 4 and 5 times in length. Since I am anticipating do more work like this, I am looking for a reasonable way to shorten these render times. I was told to consider a raid. I am currently using:
2 X 2.8 GHz Quad-Core
14 GB of Ram
FCP 6.0.6
Any help or tips would greatly be appreciated.
Also wondering if a raid would help with RT playback in Motion.
Brian
David Roth Weiss
Re: Faster Render Time
on Dec 3, 2009 at 7:51:55 pm
[Brian Bacardi] "I was told to consider a raid. "
Instead of the ___________ you're currently using as a media drive.
Unless you fill in the blank Brian no one can answer your question intelligently.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los Angeles
A forum host of Creative COW's Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Shane Ross
on Dec 3, 2009 at 7:54:22 pm
The what format of files are you working with? RAIDED drives might help a bit, and a beefier GFX card (when dealing with Motion and certain FXPlug plugins in FCP)... but other than that...processors. Faster the better. ONE DAY they'll release the hounds and get all the processors to be addressed by FCP.
Shane
Brian Bacardi
on Dec 3, 2009 at 8:02:48 pm
Hey Shane-
working with prores.
Brian Bacardi
on Dec 3, 2009 at 8:00:33 pm
Hey Dave-
Currently using a second internal HD (1.5 TB spinning at 7200).
Brian
David Roth Weiss
on Dec 3, 2009 at 8:14:49 pm
[Brian Bacardi] "Currently using a second internal HD (1.5 TB spinning at 7200)."
Well, you will find that a raid will give you much better realtime performance than a single SATA drive, and thus you will have to render less often. However, actually making renders move "appreciably" faster is, as Shane said above, more a function of faster processors.
However, when using a raid you will undoubtedly experience a vastly improved editing experience. Just striping three 1.5Tb drives internally will give you a huge boost in performance, as throughput will be nearly 3X greater.
David Roth Weiss
Director/Editor
Los Angeles
Kevin Monahan
on Dec 3, 2009 at 11:28:45 pm
Also, you can build your effects intelligently. Submaster effects by exporting them, then reimporting them. Use different filters to build your effect (use FX Plug, etc.)
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author - Motion Graphics and Effects in Final Cut Pro
