FCP transition problem using transparent Tiff
Jeremy Schoenwald
on Dec 3, 2009 at 6:25:47 pm
I'm having a problem with transitions in FCP. I have a video layer on V1 and overlay a tiff text graphic on V2 using an edge wipe (although I experience the same problem using a simple cross dissolve). The problem is that the last frame of the transition and the next frame do not match. The last frame of the transition is slightly brighter than the remainder of the graphic. I think it may be some sort of alpha issue. I tested different transparency settings on that last frame and ruled that out as the problem. Any ideas?
Kevin Monahan
Re: FCP transition problem using transparent Tiff
on Dec 3, 2009 at 6:35:10 pm
Render > Full and also check on external monitor, not computer monitor. No monitor? Set Canvas to 100% after rendering.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author - Motion Graphics and Effects in Final Cut Pro
Thax Clave
on Dec 3, 2009 at 6:43:53 pm
Is this the old "white" vs. "super white" issue?
Jeremy Schoenwald
on Dec 3, 2009 at 7:53:08 pm
Excellent Thax! That was it. Much appreciated! Is there any quality intensives to make up for this issue either in the graphics creation stage or on the FCP end of things?
