How to search markers in project window?
Ariel Brener
on Dec 3, 2009 at 8:31:19 am
I want to search markers in all of my clips.
I saw the option to search for markers on timeline
but I want to search the entire project - there is gotta B a way - please help!
________٩(̾●̮̮̃̾•̃̾)۶________
New Rig (Leopard 10.5.7):
Final Cut Studio 3
CPU: Core i7 920
RAM: 12gig
GPU: GTX 285 2GB OC
HDD: 6 X 1 TB HDDs: 4 HDDs in RAID-5 and 2 HDDs for System.
OLD RIG (Win Vista Ultimate 64bit):
ADOBE MASTER COLLECTION CS4
RAM: 8GB (Corsair 800Mhz)
CPU: Intel Quad Core 2.4Ghz (Q6600)
GPU: ATI x1950XT 256MB
MB: Asus P5K Deluxe WiFi-AP
Jerry Hofmann
Re: How to search markers in project window?
on Dec 3, 2009 at 11:40:13 am
Turn them to subclips. Then search. You can simply drag a marker in the browser window to any location and it turns into a subclip named the same as the marker was. The find command works then...
Jerry
david bogie
on Dec 3, 2009 at 3:52:10 pm
might help:
http://www.kenstone.net/fcp_homepage/fcp_7_labels_markers_stone.html
bogiesan
Ariel Brener
on Dec 3, 2009 at 4:24:06 pm
This is my first project on FCP - Migrated from Premiere CS4
Wow thats a major bummer...
I have 20 hours of HD footage.
Spread over many folders - and many many clips.
inside of them I Marked more than hundred markers.
Because I thought it will be very simple to search it up!
I dont want to go all over the markers and make them as subclips it will take hours - and will create clips that I don't want... just adds many Items in the projects...
I can't believe such a simple feature is missing! and the only markers that are searchable are markers which are shown and collapsed.. how stupid is that - I already see them - I want to search the ones that are hiding inside of folders and clips!!!
How can I find all the quetes and notes I made to miself!?
Final Cut Studio 3
CPU: Core i7 920
RAM: 12gig
GPU: GTX 285 2GB OC
david bogie
on Dec 4, 2009 at 3:00:20 pm
It's no that I don't sympathize, I do. I see this topic often.
FCP's failures in metadata handling have been known since v1 and they could have been researched easily and thoroughly before you committed to a platform that, as it turns out, coes not support your preconceived workflow.
You have two options:
1. Change your workflow to accommodate the limitations of your platform (FCP has many more benefits than drawbacks)
2. Obtain a third party application that helps handle your markers (CatDV and Cumulus are fully capable video catalogers with HUGE issues of their own)
3. Just keep complaining.
bogiesan
Ariel Brener
on Dec 8, 2009 at 7:42:47 am
Thanks - about CatDV - does it integrate into the FCP interface - adding more ways to search my already added markers?
can you please allborate more about this tool?
I went to their Website - but didn't understand how its working.
Thanks anyway !
you made me laugh!
:D
Final Cut Studio 3
CPU: Core i7 920
RAM: 12gig
GPU: GTX 285 2GB OC
Jerry Hofmann
on Dec 6, 2009 at 12:07:34 pm
It's quite fast actually to drag a set of markers to a bin... you'd do this one time per clip with markers.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Ariel Brener
on Dec 8, 2009 at 7:45:39 am
thanks I'll try to play with it... but I have so many markeres spread on so many links - also what happens If the I add more markers to a clip?
a
Final Cut Studio 3
CPU: Core i7 920
RAM: 12gig
GPU: GTX 285 2GB OC
Jerry Hofmann
on Dec 8, 2009 at 3:12:46 pm
You can add markers any time to clips or subclips, then just create another subclip from that new marker... cmd+u is the keyboard command for it.
Jerry
