3K 50fps slow motion into a 25fps sequence ?
jeremy Pitard
on Dec 2, 2009 at 10:01:52 pm
Hello
I'm editing a short movie shoted in 4K with the RED one.
I imported a 2K QT reference movie, the codec of my sequence is prores 4444 and everything works fine... but... there are alway a but :)
The movie is in 25fps... and I have only one shot in 3K/50fps... It's a slow motion shot.
When I play this shot, he's accelerated.
How can I play it into my sequence in 25fps ?
If someone have an answer, I will appreciate a lot .
Jeremy
Ps... Sorry if my english is not correct... i'm french.
Thanks Thanks Thanks
Jeremy
MAC OSX 10.5.8
Two 2,26 GHz Quad-Core Intel Xeon « Nehalem » processors
8 GB memory (4x2GB)
graphic card : two NVIDIA GeForce GT 120 with 512MB
eSATA card : SONNET TEMPO SATA E4P
My Book Studio Edition II Western Digital 2x1To in RAID 0
FCP 7.0.1
Michael Gissing
Re: 3K 50fps slow motion into a 25fps sequence ?
on Dec 2, 2009 at 10:12:28 pm
After converting the 3K red to 2k ProRes4444, open this file in Compressor and use frame controls to create a new quicktime changing the speed to play at 25 fps.
Use the same codec (ProRes4444). This new file will play as a slo mo.
jeremy Pitard
on Dec 3, 2009 at 7:25:15 am
Thanks a lot Michael ;)
I will do it !
but your answer suggest me an another question...
After the editing, the movie will send to Color and conform in 4k.
(I used the 2K QT reference movie so I thing I can reconnect the sequence to the native R3D)
is it possible to have a finish sequence in 4k with a 2k shot (the slow mo) ?
Or all the sequence will be in 2K ?
Jeremy
MAC OSX 10.5.8
8 GB memory (4x2GB)
FCP 7.0.1
Rafael Amador
on Dec 3, 2009 at 7:45:48 am
But you want these pictures in slow-mow, don't you?
if so, Conform the p50 clip to p25 on CinemaTools. Then resize in Compressor.
If you want the picture to play at normal speed in the p25 sequence. fallow Michael advise or simply drop the footage in the p25 sequence. If you do it in Compressor, make the Time-base change "Lineal". Compressor simply will drop one every two frames. This is what you need.
[jeremy Pitard] "Or all the sequence will be in 2K ? "
That will depends of your sequence size.
rafael
http://www.nagavideo.com
jeremy Pitard
on Dec 3, 2009 at 10:34:54 pm
Hello
I will test all your propositions tomorow... (cinema tools and compressor).
My producer said to me he want finish the movie in 2k after a 4k colour calibration by color... so I don't have sequence problem anymore between 4k and 3k slow mo :)
I thank you a lot for your precious advises. I love this website :)
Jeremy
Ps... when I drop the 50i footage in the p25 sequence... it doesn't work... I don't know why... but It doesn't work. May be a bug !!!
Ps2... could you tell me if my english is correct or difficult to understand ? Thanks
Jeremy
MAC OSX 10.5.8
8 GB memory (4x2GB)
FCP 7.0.1
