exporting to quicktime on FCP 5
Mike Schoneman
on Dec 2, 2009 at 9:49:39 pm
I've got a sequence in FCP 5 with 45 min of slides, audio, video and text. I try to export it "quicktime" with "current settings" not "using quicktime conversion". I cleared all ins and outs on the timeline before hand and it will export a 1.5MB file that is less than 1 second long. It's really strange I've never seen this before.
I am currently trying to render the entire sequence to see if that helps, but thought I should try to get professionals to help.
Thank you.
Shane Ross
Re: exporting to quicktime on FCP 5
on Dec 2, 2009 at 10:12:25 pm
Make sure that you have MAKE SELF CONTAIN checked in the EXPORT window.
Shane
Mike Schoneman
on Dec 2, 2009 at 10:21:21 pm
Thanks for the quick response.
Yes. I have it checked and it still does the same thing.
Any other suggestions as to why this may be happening?
Shane Ross
on Dec 2, 2009 at 10:46:08 pm
#44: FCP acting weird - Trash Prefs
Shane's Stock Answer #44: FCP acting weird or unusual. Just not like is normally should
If the program was working fine, and now isn't, or just isn't working the way it should, the first things to do are:
1) Trash your FCP preferences. Download the Preference Manager from Digital Rebellion: http://www.digitalrebellion.com/pref_man.htm
http://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
2) Open the Disk Utility and Repair Permissions.
3) Shut down for 10 min. Go for a quick walk around the block and get SOME exercise today. Come back, turn on the computer and see how things are.
4) (optional) Do the Hokey Pokey and turn your self about. Results may vary.
Shane
