More monitor advice please, greatly appreciated
Roli Rivelino
on Dec 1, 2009 at 8:07:17 pm
I've been trawling freecycle for CRT monitors, I got one but was told on here that it wasn't that great because it didn't have phosphor (ps no idea what that is!).
I don't know what's what as far as monitors are concerned and I simply cannot afford a new monitor at present at any price, hence me looking on freecycle.
so below I've pasted the specs for the next one I'm going for (Fujitsu Siemens C-700) it has phosphor 22; is that good? Your advice and comments would be greatly appreciated.
Many Thanks
Screen diagonal 17 inch (40 cm visible)
Graphics display (dependent on graphics processor)
Pixels (max. 64 Hz) 1280 x 1024
Pixels (max. 85 Hz) 1024 x 768
Pixels (max. 100 Hz) 800 x 600
Pixels (max. 130 Hz) 640 x 480
Text display (dependent on graphics processor)
Pixels (max. 84 Hz) 720 x 400
Picture size
Preset 305 x 225 mm
Maximum 325 x 245 mm
Frequencies
Horizontal 30 - 72 kHz
Vertical 50 - 150 Hz
Max. dot rate 110 MHz
Brightness (full white) min. 100 cd/m2
Dot Pitch 0.27 mm
Phosphor P22
Plug and Play VESA DDC1/2B
Setting options
Setting options
Brightness
Contrast, Input Level
Picture position (horizontal and vertical)
Picture size (horizontal and vertical),
Color temperature and custom color settings
Pincushion,Pin Balance, Corner -pin
Parallelogram, Trapezoidal distortion,
Tilt (rotation)
Moiré reduction
Menu language, OSD time & position
Activate factory settings, Degauss
10 factory setting and 10 programmable user modes
Tilt-and–swivel base
Tilt angle -5° - +13°
Swivel angle +/- 45°
Electrical values
Rated voltage 100 -240 V
Frequency 50/60 Hz
Power draw
Operating (typ.). < 75 W
Standby mode < 5 W
Suspend mode < 5 W
Off mode < 5 W
Protection class 1
Temperatures/dimensions/weight
Ambient temperature (to IEC721)
Recommended range 15°C to 32°C
Limit 5°C to 40°C
Dimensions
(H x W x D) 423 x 398 x 395 mm
Weight 14.5 kg
Reliability
MTBF (demonstated) 50,000 h
Lifetime of CRT 12,000 h
(brightness > 70 % of original brightness)
Compliance with standards
Product safety EN60950
Ergonomics GS mark
(EN) ISO9241-3, -7, -8
Radiation immunity and CE certification according RFI
suppression to EC Directive
89/336/EEC
(EN55022/B, EN55024
EN61000-3-2/-3);
TCO’99
Data cable (1.5 m) D-SUB (15-pin)
fixed on monitor
Power cable (1.8 m) For wall socket
Euro-Schuko-Type CEE7
Article code FSP : 840 002110
aka Newbie Wan Kenewbie. "The young Newbie, is now a Padawon."
System
Mac Pro 2.8Gb quad core
8Gb RAM
1x 320Gb 7200 hardrive
1x 1Tb 7200 hardrive
Nvidia Geforce 8800 512mb Graphics card
1x 1Tb external WD 'My Book' eSata
Equipment
Panasonic AG-HVX 200
Firestore FS-100
Alan Okey
Re: More monitor advice please, greatly appreciated
on Dec 1, 2009 at 10:17:15 pm
[Roli Rivelino] "I've been trawling freecycle for CRT monitors, I got one but was told on here that it wasn't that great because it didn't have phosphor (ps no idea what that is!). "
Someone was confused. All CRT monitors have phosphors. Phosphors are the small individual elements in a picture tube that light up red, green or blue when they are struck by an electron beam from the CRT gun/guns. What they probably meant was SMPTE-C phosphors, which are the standard for professional broadcast CRTs.
What's your reason for wanting a CRT anyway? If you need a CRT just to check for SD field order and artifact issues, then any CRT will do. If you want accurate color rendition for color grading, then you'll have to spend some money, even for a used monitor. Sony's PVM and BVM series are the standard, but only the more expensive models have SMPTE-C phosphors.
At this point, it's kind of silly to spend a lot on a CRT unless you happen to find a really sweet deal on an unused B-stock model or something used with very, very low hours on it. eBay always has some decent PVM and BVM monitors, so check there if you're in the market.
Alan Okey
on Dec 1, 2009 at 10:28:47 pm
I just checked out your older post in the Color forum so now I have a better idea of what they were telling you. They said "aging phosphors," not "no phosphors." The phosphors in a CRT lose brightness as they get older, so an older CRT is harder to calibrate properly.
They also referred to the fact that you don't have a calibration probe, which is an optical sensor device used in conjunction with calibration hardware or software to measure light output from the screen and make adjustments to bring it into spec. All of this type of equipment is very expensive, not something you're going to find on freecycle.
You're going to have to face the reality that if you want proper color rendition, you have to spend some decent money to get it. You can't use an old computer CRT, it doesn't work like that. The bare minimum you could get away with would be a used Sony PVM series CRT for SD. To get into HD, you're looking at $2500 or more for an entry level broadcast LCD like Flanders Scientific. If you really want an HD CRT, you're going to have to spend $1000 or more for a used Sony PVM-14L5 or PVM-20L5.
walter biscardi
on Dec 2, 2009 at 1:11:27 pm
From the sounds of it, this is a computer monitor. If you're looking for a broadcast quality video monitor, this isn't it. Not even close.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media
"Foul Water, Fiery Serpent" now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
Blog!
Twitter!
Roli Rivelino
on Dec 2, 2009 at 6:46:56 pm
I now know the difference between computer and broadcast monitors :-) thanks guys, I think I'll wait till I really need one.
many thanks
System
8Gb RAM
Equipment
Firestore FS-100
