Bin Shortcut
Eli Mavros
Bin Shortcut
on Dec 1, 2009 at 7:57:06 pm
Does anyone know a short cut to create a bin within a bin, ie: make a sub-bin? I hate pressing Apple+B and naming a bin and then having to go find that bin once it gets in it's alphabetical order and then dragging it into the bin I want to put it (which can sometime be several bins deep. There must be a shortcut, other than double clicking the bin you want it to go in and opening it up in another window and then pressing Apple+B (which is the method I usually use...but is kind of a pain sometimes, especially if that window isn't selected and the new bin just gets placed at the root anyways. I know this is small, but it is one thing I hate on a constant basis...so hopefully there is someone smarter than me out there with a trick.
Eli
Roli Rivelino
Re: Bin Shortcut
on Dec 1, 2009 at 7:59:42 pm
Right (ctrl) click inside the bin you want to create a sub-bin in and select new bin
aka Newbie Wan Kenewbie. "The young Newbie, is now a Padawon."
System
Mac Pro 2.8Gb quad core
8Gb RAM
1x 320Gb 7200 hardrive
1x 1Tb 7200 hardrive
Nvidia Geforce 8800 512mb Graphics card
1x 1Tb external WD 'My Book' eSata
Equipment
Panasonic AG-HVX 200
Firestore FS-100
Eli Mavros
Re: Bin Shortcut
on Dec 1, 2009 at 8:24:20 pm
Sometimes its the little things in life that make you happy. Some reason I never thought of that (I always assumed it made a folder in the root of the browser)! Thank you very much Roli, this should be most helpful.
Just curious though, is there anyone out there that knows a keyboard shortcut that will create a bin inside the bin you have currently have selected? Now I'm just being fussy...but I like to use the mouse as little as I can. If not, Roli's mouse solution will do just fine.
Eli
Eli Mavros
Jeremy Garchow
Re: Bin Shortcut
on Dec 1, 2009 at 8:36:31 pm
If you have a numeric keypad, you hit option enter (keypad enter, not return) which will open that bin in a new tab, then hit command-b.
Jeremy
Eli Mavros
Re: Bin Shortcut
on Dec 1, 2009 at 9:27:17 pm
Ok, cool. Then I can hit control+w to close the tab once I have created my bins. I like it. Thanks.
Best,
Eli
Eli Mavros
Kevin Monahan
Re: Bin Shortcut
on Dec 2, 2009 at 4:41:07 am
Option double click on a bin it opens in a new tab as well.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author - Motion Graphics and Effects in Final Cut Pro
Roli Rivelino
Re: Bin Shortcut
on Dec 2, 2009 at 6:49:33 pm
Get into using your mouse wheel as well, it'll open up a world of joy for you :-)
System
8Gb RAM
Equipment
Firestore FS-100
