FCP export issue with transparent layer
Boris Undorf
on Nov 30, 2009 at 8:50:05 pm
I am exporting a project from FCP Studio 2 in which several elements were imported .gif files of images on a transparent alpha layer. I keyed out the background using "Luma Key". I also put another filter "Earthquake" onto these clips. Now, when I export the project using Compressor, in any format other than current settings, the background of these images shows up as a transparent green box. This happens with m2v files, DV/NTSC files, etc.
What do I do?
Shane Ross
Re: FCP export issue with transparent layer
on Nov 30, 2009 at 8:58:06 pm
The only codecs that support Alpha Channels are ANIMATION and ProRes 4444. ANything else and you lose transparency.
Shane
Boris Undorf
on Nov 30, 2009 at 9:01:07 pm
Thank you so much Shane for clearing that up so quickly.
So if a client requested a H264 file, I am screwed, right?
Shane Ross
on Nov 30, 2009 at 9:20:01 pm
[Boris Undorf] "So if a client requested a H264 file, I am screwed, right?"
If they want one with an Alpha Channel, then yes. That is an impossible request to fulfill.
Shane
Zak Mussig
on Nov 30, 2009 at 9:30:00 pm
This came up a lot a couple of years back and became a big part of my workflow for a very big project (to me at least) that I was working on.
Compressor is no good, and since you're in FCS2 ProRes 4444 is out. The way to export from FCP with alpha is:
1) Move your video up to v2 or above
2) don't render - that bakes in the black pixels FCP uses to display transparency
3) Export > QuickTime Movie, self-contained, Animation codec
That should give you a .mov file with an alpha channel that holds up in any QT based app. The file will be big.
Zak
Boris Undorf
on Nov 30, 2009 at 9:34:24 pm
Excellent advice, thank you Zak. I will give that a shot.
