Compressor keeps compressing
Jarrod Boord
on Nov 30, 2009 at 10:51:47 am
Hi all,
having a problem compressing any files in compressor to mpeg2 program stream. Once the progress gets to 99% it doesn't finish and the file size just keeps getting bigger until it fills up my hard drive. Any suggestions? Compressor version 3.5.1
Has anyone else had this problem?
Rafael Amador
Re: Compressor keeps compressing
on Nov 30, 2009 at 5:42:52 pm
Clean the "History Window".
That used to happen to me.
It seems that Compressor re-take threads that you may have stopped or so.
rafael
http://www.nagavideo.com
Jarrod Boord
on Nov 30, 2009 at 10:31:14 pm
Thanks Rafael, I'll try that
Jarrod Boord
on Nov 30, 2009 at 10:41:41 pm
No. Clearing history did not work. My brothers machine is doing exactly the same thing!
Rafael Amador
on Dec 1, 2009 at 4:05:04 am
Hi Jarrod,
Try this:
http://www.digitalrebellion.com/compressor_repair.htm
Rafael
Jarrod Boord
on Dec 1, 2009 at 4:13:43 am
Thanks. I have tried the repair as well. Still no love... I have found a work around now. Export compressor as standard 90min DVD file, m2v and ac3 files, then import into MPEG streamclip and Mux the files. you have to name both files exactly the same name (except the extension) and keep in same folder, then drag into MPEG Streamclip the .m2v file and export to mpeg with mp2 audio. You cannot put the bit rate above 9000 but it is good enough for this one. I think the issue is somewhere in the Muxing stage of the compressor process.
What a pain, but it will work for this job. I will do a fresh install soon!
Thanks for the help
Rafael Amador
on Dec 2, 2009 at 1:15:04 am
Hi Jarrod,
Is OK as workaround, but you should skip the AC3 step, otherwise you compress your audio twice
Do the same but instead of AC3 do it AIFF.
Rafael
Jarrod Boord
on Dec 2, 2009 at 2:58:16 am
Good point Rafael.
Cheers
joe hafera
on Dec 2, 2009 at 4:31:37 pm
I'm having a similar problem. I just installed the latest FCP update, so now Compressor 3.5.1.
when i submit my job, all default settings Apple Devices:H.264 for iPod and iPhone, the task just continues to increase in time remaining and never completes.
I have tried the digital rebellion fix, the clearing my history fix, the restarting my cpu fix, on and on...
I'm running out of hope and ideas. my old compressor used to rock and roll, and now that i updated, it's yet to work.
joe hafera
on Dec 2, 2009 at 6:12:01 pm
now all my jobs are failing almost instantly. i'm guessing i need to re-install the software. how do i re-install the software without having to re-install the entire update?
Rafael Amador
on Dec 3, 2009 at 5:42:21 am
Hi Joe,
in Library/Receipts, delete the last Compressor Receipt and try to re-install.
rafael
