Exporting Still Images from Sequence
Zack Stoff
on Nov 30, 2009 at 1:39:51 am
I have a sequence of 500-600 jpeg images which are in a specific order in my timeline. I want to export them while maintaining this order. When I drag them back into a new bin to perform a batch export, they are automatically re-ordered by title in the bin, thereby disregarding all the editing that went into their order. How do I export them without this happening so I can retain their order outside of Final Cut?
Chad Brewer
Re: Exporting Still Images from Sequence
on Nov 30, 2009 at 3:13:13 am
Seems like you have them in perfect order on your timeline. I would change each image in the timeline to 1 frame in length and then export the timeline as an image sequence which will give you a still of each frame. Is that what you are trying to achieve? A still of each image in your edited sequence?
chad
TeleVersions Broadcast Video
Chad Brewer
on Nov 30, 2009 at 3:17:21 am
If you want them exactly how they are now in your sequence with effects, etc., export the sequence to a Quicktime. If you want stills without transitions, refer to my last post.
chad
