Playhead / Canvas Weird Issue...
Dean Stapleton
on Nov 29, 2009 at 5:03:01 am
Hi fellas, I'm having a little issue...hope you guys can help me figure it out.
Right now I'm working with some Canon 5D Mark II footage. I transcoded the footage using Cineform Neo Scene. I loaded up a few clips on the timeline and I noticed that even though the play head is not on a clip, I see a clip playing in the canvas window. See attached screencap:
http://www.captureproductions.com/fcp.jpg
I'm running Mac 10.6.2
Final Cut Pro 7.0.1
Here's my hardware profile:
http://www.captureproductions.com/hardware.gif
Any ideas what may be causing this?
Thanks a bunch!!!
Josh Olenslager
Re: Playhead / Canvas Weird Issue...
on Dec 3, 2009 at 5:17:16 am
Maybe check your video settings -- If you've created a custom setting it can affect that. My viewer displays the last frame of video I had my playhead on until I move it to a new frame of video even if I'm hovering over an empty spot on the timeline; just how I have it set up personally. You might also try using an easy set-up option. I'd first try reseting your video settings to default--that will probably do it; if that doesn't work, use the easy set-up option that most closely matches what you're doing. I imagine that the problem is originating in the video display settings. If it turns out to be a larger problem, might be something with the playback speed, but you would probably have noticed that by now.
Hope that helps -
Josh
Josh Olenslager
working on better ways to video
