FCP 7 Preview problems
john lafferty
on Nov 26, 2009 at 1:47:59 am
OS10.5.8
Macpro 2.1 8 core
5GB memory
External E-SATA storage via CalDigit 4 connector card
FCP 7.0.1 installed as up-grade
QT 7.6.2
I'm working in an SD project and recently, Video Preview on my 2nd DVI attached monitor has started acting strangely. In a sequence, it will not up-date in real time - just up-dates when I finish playing the seq. Same if I match-frame from the canvas - but if I load a clip into the viewer the reverse happens - video plays at 30 fps in the preview monitor, but doesn't up-date the viewer until I stop playing.
I can scrub thru footage and both screens seem pretty close.
UNLIMITED playback is not available on my timeline - I have lots of large stills and a mix of lo-res formats all up-rezzed to 720x480.
This also happens in other projects where I've never seen this.
I've trashed prefs, re-booted etc. No luck.
Suggestions??
--john--
