iMac, Final Cut, and External monitor -- HELP!
John Miller
on Nov 26, 2009 at 12:49:10 am
Hi, I tried searching but didn't find what I'm looking for.
I have a mid-2007 iMac that has a mini-DVI output port. I'm getting an LCD
widescreen (full HD) monitor and hook it up to my iMac using the adapter.
When I'm cutting in Final Cut Pro 6.0, I want to move the Canvas over to the
external monitor, and expand it so I can see my picture larger..
That is not the problem, but, when I go to full screen (command + F12) can I see
the full screen on my external monitor, or would it still show on my iMac?
I know I can go up to View>Video Playback> and choose Digital Cinema Desktop Preview Main
When I attach and configure my other monitor, will it show up in the Video Playback menu?
I assume that if it does, I will be able to preview full screen on that monitor now.
Thank you for any help or suggestions.
Jerry Hofmann
Re: iMac, Final Cut, and External monitor -- HELP!
on Nov 26, 2009 at 12:30:08 pm
The LCD is a TV set or a computer display?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
John Miller
on Nov 26, 2009 at 7:40:35 pm
Hello Jerry,
The LCD is a computer display. I will connect it using a mini-DVI to DVI adapter from my iMac to the LCD display.
John Fishback
on Nov 27, 2009 at 5:58:38 pm
Here's a post that might relate to your question. I don't know if your iMac's display card does any "cleaning up" of the signal. http://forums.creativecow.net/readpost/200/883587
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Jerry Hofmann
on Nov 27, 2009 at 12:40:49 pm
You will be able to choose either monitor for full screen playback. But it won't be exactly what you'd see on a TV set because the gammas are different between the computer display and a video monitor or TV set, so it's not the best for color correction. If the source material is interlaced, then it will sort of tear during playback because a computer display is progressive only. There are fixes for this, but just keep that in mind...
Jerry
John Miller
on Nov 28, 2009 at 5:44:42 am
Thanks Jerry and John.
All I need it to do is playback in full screen.
Thanks for your help
