Capture card (HD) for Xbox 360
Brian Baldomero
on Nov 24, 2009 at 8:29:23 pm
I don't exactly know where to put this, but since I work with Final Cut I chose to put it here.
I'd like to capture some footage of me playing Xbox360 but the only things I've found was capturing stuff in Standard. I do like to play the games in full HD so I don't want to hit the switch on the back of the XBOX to play in standard. I currently work on a MacBookPro. How do I capture myself playing in full HD?
Richard Sanchez
Re: Capture card (HD) for Xbox 360
on Nov 24, 2009 at 9:13:12 pm
You'd need the AJA IOHD or the Matrox MXO2 to capture via HDMI.
Richard Sanchez
North Hollywood, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
John Fishback
on Nov 24, 2009 at 9:33:48 pm
Or a converter like the AJA HA5 that converts HDMI to HD-SDI, and then use that with your capture card.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Brian Baldomero
on Nov 24, 2009 at 10:28:05 pm
I forgot to add. I am connected thru component. Is their a way to do it thru component?
John Fishback
on Nov 24, 2009 at 10:42:22 pm
Checkout the other AJA mini-converters. There's probably one to go from component to HS-SDI.
John
gary adcock
on Nov 25, 2009 at 3:15:52 pm
[Richard Sanchez] "You'd need the AJA IOHD or the Matrox MXO2 to capture via HDMI. "
Nope.
Since Xbox materials have copyrights the HDCP requirements on the HDMI will prohibit capture digitally.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Richard Sanchez
on Nov 25, 2009 at 6:42:37 pm
I was afraid there'd be a gotcha like that!
Richard Sanchez
North Hollywood, CA
Atticus Culver-Rease
on Nov 25, 2009 at 12:35:36 am
I've done this before, and I had to capture via component because the HDMI output has HDCP. I know the AJA IO doesn't support HDCP, not sure about other options like the Matrox stuff. When I did it I went component into a Folsom ImagePro HD scan converter and spit out HD-SDI to capture into my system through a Kona 3. Depending on your setup you may be able to go in component directly or use a cheaper converter, but I had the ImagePro handy and knew it would work. The other thing is that the audio output is unbalanced so I had to convert that to feed it to the Kona as well.
You said you're on a Macbook Pro, what sort of capture device are you using?
Andrew Kimery
on Nov 25, 2009 at 2:10:24 am
Capturing via HDMI can be problematic because of the HDCP encryption. You can buy boxes that say they'll spoof the HDCP but those are spotty as well. We do a ton of gameplay capture and it's all done via component.
-Andrew
3.2GHz 8-core, FCP 6.0.4, 10.5.5
Blackmagic Multibridge Eclipse (6.8.1)
gary adcock
on Nov 25, 2009 at 3:29:57 pm
[Atticus Culver-Rease] " I know the AJA IO doesn't support HDCP, "
Got that backwards- ALL Aja products DO support HDCP digital rights management over HDMI.
gary adcock
Studio37
Chicago, IL
on Nov 25, 2009 at 11:15:41 pm
Hmm, well I never actually tried it, but the IO HD because the manual says, "HDCP is not supported on either input or output." Is that incorrect?
Andrew Kimery
on Nov 26, 2009 at 1:02:09 am
The Ki Pro manual says the same thing.
-A
Stuart Simpson
on Nov 27, 2009 at 4:30:08 pm
These guys specialise in videogame capture hardware:
http://www.digitalfoundry.org/
-Stuart
7 MacPros - Kona 3, Kona LH & Kona LHi
1 G5 - Kona LH
xbox360, Wii, PSP, PS3
http://www.speak.co.uk
Andrew Kimery
on Nov 29, 2009 at 4:48:29 pm
My experience w/Digital Foundry's gear has been less than impressive. We've used laptop and small form factor PCs from them and are still looking for something to meet our needs. We use DF for a lot of mobile/on location capture and maybe the units would provide a better experience if they weren't used in this type of on-the-go fashion.
-A
Mario Rubertis
on Nov 29, 2009 at 5:05:55 pm
Brian,
I think someone has already done what you wish to do and created a step by step tutorial.
Check this out:
I hope this helps.
An Artist At Heart.
Life is made of moments...
