Audio blips in timeline, but not in audio file
Mark Drewe
on Nov 24, 2009 at 3:08:11 pm
I've got some audio clips in my timeline that seem to have blips in them when it plays through and when it renders (sometimes) - however when I play the original audio file outside of FCP there's no blips. Is there any way I can resolve this issue?
Dave LaRonde
Re: Audio blips in timeline, but not in audio file
on Nov 24, 2009 at 5:50:21 pm
If the audio is NOT aiff, 48kHz sampling and 16 bits, change it to that.
Dave LaRonde
Sr. Promotion Producer
Mark Drewe
on Nov 24, 2009 at 8:12:07 pm
That worked perfectly. Thanks!
John Fishback
on Nov 24, 2009 at 9:42:51 pm
If you're using a Kona card without a ref signal fed to it, that can produce noise in the signal.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
