DG Fastchannel settings
Dan Hayes
on Nov 23, 2009 at 8:27:05 pm
Hi All,
I need to do an encode for DG Fastchannel with the following specs:
Video: 18MB/s
MPEG-2 Program Stream
4:2:2
9 frame GOP
29.97fps
4*3 Aspect Ratio (If captioned the file needs to be
720*486), 720*480 (recommended)
Interlaced lower Field first
Audio: MPEG-1 Layer 2
2 Channels
48KHz
20bit
384Kbps (recommended)
I've just purchased Telestream's Episode since FCS can't meet their specs. Can someone send me a Telestream Episode settings file that will cover these settings? I'm especially mot sure what settings give you the "9 frame GOP".
Dan
email: djhayes DOT sf941 AT yahoo DOT com
Jeremy Garchow
Re: DG Fastchannel settings
on Nov 23, 2009 at 9:44:22 pm
Telestream will help you out if you call them.
Jeremy
