crash on export
Jack Blandford
crash on export
on Nov 23, 2009 at 7:11:05 pm
Has anyone had this problem. I try to export, using the "using quicktime conversion" tab. It spins the dreaded pinwheel, then crashes the system. help. jack
Nicole Haddock
Re: crash on export
on Nov 23, 2009 at 7:16:35 pm
I think if I could take away one feature of FCP, it would be the QT Conversion option.
Export to Quicktime, then do whatever compression you need.
Jack Blandford
Re: crash on export
on Nov 23, 2009 at 7:41:44 pm
Is there another way to export a still then?
thanks
jack
John Fishback
Re: crash on export
on Nov 23, 2009 at 9:38:37 pm
It's possible that part of the the media you're trying to export is corrupt. Try exporting a different frame. What exactly is your export workflow. What type of still are you trying to export?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Nicole Haddock
Re: crash on export
on Nov 23, 2009 at 9:40:53 pm
You can do a standard screen grab and then crop it down in Photoshop- Apple+Shift+4 which then gives you a cross hair to drag around whatever you want to capture. File will show up on your desktop in TIFF, PDF or PNG format.
John Fishback
Re: crash on export
on Nov 23, 2009 at 8:00:45 pm
What Nicole says, then use Compressor to encode. It's faster, too.
John
