Lost audio on import of video
Jim Reed
on Nov 22, 2009 at 9:56:28 pm
I'm very new to FCP. I ran a 4 hour video through Mpeg Streamclip and converted it to an mpeg. The audio was converted at the same time. I have the video on a disk and it plays fine with good audio. However, when I imported it in to FCP, the video came in, but know audio.
1. Any idea what I did wrong.
2. I had to render the mpeg in FCP before it could be viewed in FCP. Is this common or should I use a different extension instead of mpeg.
Thanks for the help.
Nicole Haddock
Re: Lost audio on import of video
on Nov 23, 2009 at 3:34:41 am
FCP doesn't work with MPEGs, as you've seen. Next time convert the file to a Quicktime using MPEG Streamclip or your converter of choice and you should have audio.
Jim Reed
on Nov 23, 2009 at 1:41:51 pm
In Stream Clip, there is a function; Export to Quicktime. Is this the one I should use? I'm use to using AVI or MPeg in Adobe, I can see this is going to change.
Thanks for the reply.
