exporting canon 5d mark ii footage
Florencia Garcia
on Nov 21, 2009 at 10:01:08 pm
I'm fairly new to final cut, im running a Mac Pro, 2 X 3 Ghz processor, 10GB memory, 10.6.2 snow leopard... and i still find myself having to render at every edit in the timeline, and now im having trouble figuring out how to export correctly to get the highest possible quality on youtube and/or vimeo
here's what i have done and researched so far:
i took my original canon 5d footage into MPEG streamclip and converted the files into Apple ProRes 422 (LT) at 30fp, i then created a custom setup in final cut 7 with the following presets:
SEQUENCE PRESET: Canon 5D Mark ii footage (duplicated an Apple ProRes 422 (LT) 1920X1080 30p 44.1ghz audio)
CAPTURE PRESET: DVCPRO HD 1080p30 48kHz (i won't be capturing in fcp since i've been using MPEG streamclip
VIDEO PLAYBACK: (sometimes i have this set at Digital Cinema Desktop Preview - Full Screen so that i can take advantage of my other monitor, but it tends to drop frames faster in playback, so i usually have it set to "none")
now my question is, how do i correctly export this? i tried a couple different ways, some had skipped frames... others the audio was off... another setting made the colors way too contrasty after exporting...
also how can i solve this "rendering" issue... did i make a mistake in the beginning in setting up the timeline (btw , the sequence matches the same settings as the footage... ) i'm also playing back at "safe RT, medium quality, half frame rate..." not sure if that matters..
so yeah, my two main questions are, correct export for this file, and any help with render issues?
thank you..
sequence info:
<img src="">
clip info:
<img src="">
here is a link to what i uploaded using Quicktime X directly to youtube..
it doesn't look as good as i think it could...and it has a HQ option instead of HD? i don't have quicktime pro so i couldn't export with exact settings, just directly to youtube... how can i export w/ final cut .. when i export using quicktime conversion and using Apple Pro Res, it ends up being a 1.34gb file and its only 1 minute... would i then need to compress it?
and yes i need to get rid of all the layers i have in the timeline.. maybe that might help but it was giving me the rendering "RED" color even in the beginning when i had 1 layer..
i changed audio to 44.1 because i read it somewhere online i believe it was under phillip bloom.. suggesting to change from 48 to 44.1 for all canon 5d footage.. ? im not sure why though..
Shane Ross
Re: exporting canon 5d mark ii footage
on Nov 22, 2009 at 7:42:57 am
As I mentioned on the Apple forums... The ProRes LT codec in FCP is 29.97fps...not straight up 30fps. You need to convert your footage to 29.97fps...
© 2018 All Rights Reserved
