burn in time code on a sequence with fcp7
stephen johnson
on Nov 20, 2009 at 9:37:24 pm
Hi
I am trying to add a time code window to a short sequence (12 minute) in FCP 7 I used the timecode generator filter but it resets to zero at every edit so that doesn't work. then I put black slug on a second video track and keyed out the dark and that was fine but it seems I can only lay down 2 minutes of black at a time so the time code window goes away at the edit of each section of slug, I would happily reset the time code generator at each cut to provide accurate window but I cannot seem to be able to tell the timecode generator where to start the code,
any help
Paul Figgiani
Re: burn in time code on a sequence with fcp7
on Nov 20, 2009 at 9:47:33 pm
Nest the sequence and add the TC Generator Filter to it. Or use Andy's TC Generator above the existing edited sequence.
-paul.
stephen johnson
on Nov 21, 2009 at 7:04:03 am
paul .....
thanks so much, that worked great
steve
