nikon d90 capture limitation
mahesh dood
on Nov 20, 2009 at 4:04:12 am
hi
i have a nikon d90, the HD movie option does not allow me to record more than 5min at a time. is there a way to bypass this problem, since sometimes i need to do longer recordings.
what can be done?
mahesh
Shane Ross
Re: nikon d90 capture limitation
on Nov 20, 2009 at 4:59:26 am
UH...what does this have to do with FCP? Shouldn't you be posting this on a Nikon forum?
Shane
Arnie Schlissel
on Nov 20, 2009 at 10:05:12 pm
[mahesh dood] " is there a way to bypass this problem, since sometimes i need to do longer recordings. "
Well, the obvious workaround is to use a different camera...
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
mahesh dood
on Sep 14, 2010 at 10:25:17 am
hi
in my nikon d90 setings i set the video to 720p, which means the video should record at 1280x720p. after recording video via the USB i copy the video files to my comp, the recorded video is not 720p but 480p. i am unabla to figure out why and what to do to make the camera record in HD?
sos, bought this camera only for this reason that it could record HD
thanks
mahesh
Rafael Amador
on Sep 14, 2010 at 10:54:08 am
[mahesh dood] " after recording video via the USB i copy the video files to my comp, the recorded video is not 720p but 480p"
You don't have to "capture video", but to use the Log & Transfer function.
read the last Shane's tutorial about Tapeless Workflow.
rafael
http://www.nagavideo.com
