5.1 surround from FC to HD1400 deck?
nicolas jolliet
on Nov 19, 2009 at 9:42:47 pm
Hi all,
I can't find any info on how to send the 8 tracks (5.1 plus stereo mix) from my FC sequence to a DVCpro tape in a HD1400 deck.
Is it possible? someone has done it? What is embeded tracks ?
Any help would be greatly apreciated.
Chris Borjis
Re: 5.1 surround from FC to HD1400 deck?
on Nov 19, 2009 at 11:04:54 pm
have you routed the outputs of your various surround and stereo
stems to the appropriate audio outputs in fcp?
this is under the audio options in preferences I think.
Michael Gissing
on Nov 20, 2009 at 8:41:01 am
Don't know that specific deck but how many audio channels can it record? If it is opnly four then you can't send the 5.1 mix (6 channels) plus a stereo.
There is a way to encode the 5.1 mix into a data stream that records onto a tape deck as a two channel stream. Look up Dolby E.
You are better off getting a facility to create the Dolby E track and restripe it onto your tape.
nicolas jolliet
on Nov 20, 2009 at 5:51:30 pm
Since I am on a small budjet I was trying to avoid going to a facility to do that.
The Idea is to go by my friend's studio and use is HD-1400 deck.
My friend tells me that I can't take 8 audio tracks to the deck, but on the manual it says that it takes 8 embedded tracks so it should be possible to do it without ecoding to dolby E.
Anyone?
Michael Gissing
on Nov 21, 2009 at 12:15:15 am
Either your friend is not aware of his deck or it may require an option to take 8 channels. I can't answer that for you so you need to find out from your friend and do a test.
As far as FCP goes, you need to set up your sequence for 8 channel output, patch each channel to i a discreet output and have an I/O card with SDI and 8 channel capability. Kona, Matrox and Decklink should all be OK with 8 channel embedded but firewire won't.
nicolas jolliet
on Nov 24, 2009 at 9:27:17 pm
Ok, so this should do, I 'll go out of the kona with Hd-sdi routing the 8 outputs.
Thanks for you help guy's.
